MikeXM
- Joined
- Nov 30, 2019
Amazon item... See post #76.I need that syringe. When I ordered, did I miss it?
I'm rather optimistic though that adding 3 to 8 ounces of additive to a 32 gallon tank of fuel which equates to over 4,000 ounces, that the additive isn't totally diluted away to nothing, thus having no value at all! But since I ran over 110,000 miles on the EcoDiesel with no fuel pump issues, I'll keep using the additive!
Looked for them but couldn't find any. So I just bought 2 bottles of Gumout injectors cleaner and drop them into 2 cars. And now they work great for diesel additives.Does anyone know of a place you can buy long neck bottles for single use additives? I'm currently using the EDT squeeze bottle but after looking at how much cheaper it is to buy in bulk I plan to just order a gal or EDT and a gal of DWAG and buy a few 4oz bottles that I can fill additive into so I'm not having to pull out the little funnel every fill up.
The only other thing I can think of would be to find single use bottles with long necks and then just repurpose them, but I'd rather not risk using something subpar or just dump it since that seems wasteful.
Also surprising to me anyway, there is a patent to the long neck bottle. You read that right, someone has a patent that expires in 2034 for a bottle with a long neck.
Good question. Never seen it on any product documentation. Which makes me think it is long, otherwise they would publish a number?What is the shelf life once opened for the EDT? I'm only averaging 500 miles a month, it'd take me a bit to use a gallon.
If I purchase any of your products in a larger quantity, say by the gal., how long is it useable, the shelf life?
A:
Shelf life for our products is a minimum of two years when sealed and one year opened. If sitting for a long time period, just shake up before using it.
Thanks for posting that. Their current code is for free winter anti-gel, which living in Oklahoma isn't really much of an issue. I used the code you shared and it still worked as of today.Try code 32zEDT
That's the one that popped up after I entered email.
I like the idea. Once you have made a level line on your smaller bottles, it should be quick to fill. No measuring.Don't see where anyone has suggested this, but these work great for buying in bulk and transferring to the smaller, more easily carried containers.
Hey man i know this post is kinda old what exactly did you order wanting to refill my bottle bc it’s easier to fill my small Lucas bottles from the squeeze container I tried a syringe and hose from there but it didn’t work hose barely went past the first bend so it just kept filling the top one ounce measure spotI'm using a large syringe with tubing from amazon to transfer from the gallon jug. It just works great. No mess.
I use two "capless compatible bottles" to hold the additive until fill-up's.
