Articulink? Technical discussion
UglyViking
Jul 11, 2020
That joint will allow more vibrations to the chassis and will have a significantly shorter service interval than the vulcanized rubber joint’s service life. It will allow more flex and it is serviceable but overall I think it’s a downgrade.
That's something I've been thinking about for a while. I know Carli uses these joints on their radius arms, vs the OEM vulcanized rubber that Thuren uses on his. I think the primary question between the two is are you willing to trade maintenance requirements for articulation?
I've never had radius arms with these joints but you think there is that much chassis vibration coming through?
Crusty old shellback
Apr 10, 2021
Of course rear coil spring rate comes into play. Anybody know how the spring rate compares between PW and non-PW 2500s with gas engines?
Regular 2500 is stiffest. PW is in the middle. Thuren is the softest. Got that straight from Thuren.
Trail_Wagon
Dec 3, 2021
Looks like he finished up. I think it's one of the new 3.0 Johnny joints at the frame. Bung is welded in nice. Pretty slick for very little money.
Johnny joints don't transfer vibration to the cab. That's marketing BS. They also require nearly no maintenance.
UglyViking
Jul 11, 2020
I do wonder why not just do a 4 link at that point? Like, even with all this additional flex, a 4 link is still going to flex more right? Perhaps this is right in that sweet spot?
Darkone
Nov 30, 2020
West Virginia
A 4 link would add more work, this was a relatively easy modification. As far as benefit for amount of work, Im not familiar enough with those joints to say. I will say the vibrations that could be transmitted back into the frame couldn’t be as bad as what my current transforce tires send back.
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
I do like the ability to push the axle forward a little with this modification. I need 1/2”
thkbaron
Nov 29, 2021
no you can't........well you could but you'll fk your shocks up and your springs won't sit right.
thkbaron
Nov 29, 2021
Oh please tell me more about the things I can’t do. I especially want to hear how I’d mess up my shocks.
Well the shock is hard mounted at the top and isn’t meant to articulate forward and rearward. I’m sure the springs could handle the movement. Not sure the shocks would like it. I mean i could be wrong.
Trail_Wagon
Dec 3, 2021
The top of the shocks is basically a bolt that goes through two rubber isolators. Remember shocks don't hold up anything, only dampen oscillation. They wouldn't be the least but bothered by the axle being moved 1/2. Springs don't care either, although it might cause them to bow slightly.
Actuall areas of concern would be steering. You don't want drag links, track bars, and diff covers trying to share the same space... But 1/2 is probably in the realm of okay.
Rockcrawlindude
Jan 1, 2021
Georgia USA
you are. Lol.
When you lift the truck, the radius arm effectively becomes shorter. It needs a little more length to be correct. I’d like to get that length without a drop crossmember relocating it
Think of the front suspension as a triangle. The distance between the top coil bucket and the frame mount of the radius arm is one length. The distance of the radius arm is the second length. The distance between the two coil buckets is the third length. If you change the length/height of the coil without lengthening the radius arm you get a tire that isn’t centered in the wheel arch.
Darkone
Nov 30, 2020
West Virginia
I would think the 1/2” might help with re centering your axle after leveling/lifting. Wasn’t that kinda the rule of thumb with 3rd gens after a leveling kit to really center everything was 1/2” long control arms. I know the suspensions are different long arm/short arm vs radius arm but I feel the concept is the same.
Lifting the suspension but keeping the radius arm/ links the same pulls the axle back, even if it’s just slightly. Everyone combats this by adjusting their caster but this seems to be a simple fix to that.
Now I’m no engineer nor do I have much background in building or racing suspensions, so if I’m missing something let me know.
loveracing1988
Feb 16, 2021
you are. Lol.
I'd again request SOMEONE try this kit out because I don't want to be a guinea pig... It could definably help out your being too short problem...
Lumpskie
Nov 11, 2021
I saw this on Instagram... Pretty cool. This guy replaced the frame side articulink bushing with a 3.0 joint. Less slop, but still maintains flex, since all the magic happens at the axle anyways.
I've thought about doing this in the past. From my tests, I wasn't getting bind at the rearward joint. (80 series Land Cruiser guys used to to this as well. They would either replace the rear joint with a spherical bushing like this or add a joint to allow for longitudinal rotation.) In my Land Cruiser experience, though, this joint didn't really provide extra performance. The bind in the radius arms came in the axle side joints. Now, I know that the articulink already addresses axle side bind with the added joint. But, I'm curious to see where the bind in a stock articulink really happens... and if it really fully binds at all. Do you know what springs and shocks this rig is using? I'm wondering if he is trying to do a version of a long travel suspension on stock-like radius arms. (which I think is a cool idea) Maybe if you are trying to run 14" travel shocks on radius arms, I could see this really coming into play. Keep this thread updated as this thing gets tested!
Apr 10, 2021
Finally found this old thread.
Has anyone else read thru this?
Metacloak has a similar radius arm to what this guy did. They also had a special Johnny joint they sell that may be worth looking into.
Darkone
Nov 30, 2020
West Virginia
Seems like he created his own power wagon. I’d be curious to see his flex/ ride quality vs a stock power wagon. He might have a hair more flex over a power wagon with the sway bar locked due to the torsion sway bar though
Lumpskie
Nov 11, 2021
@Crusty old shellback Just my opinion but I think the articulink arms would net more flex than those metal cloak ones. The bushings need to actually absorb translational motion at the axle side... not just rotation. Picture the drivers side of the axle wanting to roll forward and the passenger side wanting to roll backward to flex. The only way to allow that motion is to allow the center point of the bushing to displace towards the edge. Spherical bushings wont allow for that where rubber ones will. That's the beauty of the articulink arms, if you as me. They have 3 bushings in front... all of which are rubber. If you look at that thread, it appears that Trail_Wagon's PW has more flex than the OP's rig.
