XH7- Tow mode camera (wired)- $450.
You would choose this option if you already have a package/group selected that includes the digital rear view mirror.
AVF- Tow Mode digital rear view mirror package includes wired tow mode camera- $945. You would chose this package if you want the tow mode camera, but do not want a package/group that includes the digital rear view mirror.
This is a digital camera that can be mounted anywhere you want, and will display in the rear view mirror. It will be the default view when it is plugged in, and the digital camera in the CHMSL will be the default view when it is not plugged in. You can toggle between both views when the tow mode camera is plugged in. This camera system is completely divorced from any other camera system offered, so there should be no reason why this option can’t be equipped when other camera options are chosen.
Here are a few images- one of what the tow mode camera wiring connector looks like that you would plug into a receptacle on the bumper, and one of the location of the bumper receptacle. This is a separate receptacle from the 12/7-pin trailer tow connector. I can’t say for sure, but for 5th wheel prep, this receptacle might also be in the bed, and you would manually switch the connection like you would on a 5th wheel prep with the 12/7 pin connectors.
