TinGoatTravelers
Apr 24, 2022
Are you using dielectric grease on the connector and rings?
No. I do on the 7-pin but hadn’t thought of it for the camera cable…good suggestion. Still - the fit of the plug into the socket is exceedingly tight. These little o-rings are going to get chewed up either way so I’m going to want a supply of them for sure. Thanks.
gator6
Nov 9, 2021
On the road, USA
I do think having a stock would be a good thing, but definitely put the grease on there. [mention]mbarber84 [/mention] has already posted about the unused connections showing signs of oxidation.
Jsboening
Dec 30, 2021
Thanks! I had a stomach-turning moment yesterday when I had to cut a hole for the dryer vent my wife wants to be installed for our trip. Something about cutting into a vehicle with a hole-saw.
That takes ballzzz.
TinGoatTravelers
Apr 24, 2022
To be clear - you’re suggesting dialectic on the o rings as well as inside on the connection points of the cable? I have no problem with that on my 7-pin but for some reason I’m concerned about greasing the electrical part of this particular cable. I’ll be fine really :cool:
gator6
Nov 9, 2021
On the road, USA
I put a thin coat on all my camera connections. Learned that one from my comms guy when setting up or boats for missions.
TinGoatTravelers
Apr 24, 2022
Ok -2 things:
First - to Brutal_HO and gator6 - thanks for the grease suggestion. We went camping this weekend and getting the plug in and out was MUCH better! I think I was nervous that the camera cable is so unique that anything that touches it would kill it - I was wrong. Works like a charm. I still want a bag of those o-rings though and haven’t heard back from anyone I’ve contacted on exactly what size and/or part number…
Second - on my concern about the camera automatically pointing down in reverse, I learned in real time you CAN NOT adjust this setting while in reverse! That really screwed up my plans. Now, this may have been obvious to everyone else, but it just dawned on me today that since it always starts in the position you left it in (meaning, whatever you’ve set for brightness controls, up/down, L/R, level, is where the camera/mirror is when you start the truck with the camera plugged in), I could just reset the visual field location to be what I want when the camera is in its lowest position. Just did it and tested that when it goes in to reverse there’s no where else for it to travel! So it will keep the view I want and it’s almost exactly in the position I originally set it to. While there are many click points on the mounting bracket, they’re not micro-millimeters apart - but it’s close enough for jazz so I consider this a victory in terms of tricking the camera to do what I want!
gator6
Nov 9, 2021
On the road, USA
Ok -2 things:
Not a problem! Our purpose here is to offer advice make everyone’s experience better. Before talking with [mention]beckty85 [/mention] a couple weeks back, I had no idea the camera panned down while in reverse, but I had adjusted it so I could see about 15 yards astern while in the low setting in cab.
I’ve got two new cables in now to fix my length issue. A 6.5’ and 10’ to go along with the current 6.5’ extension. I think I should be good with just the 10’, and considering that only adds 3.5’ to my current setup, I should be good. I came up JUST short with a 6.5’ extension, the sharp turns while moving around my buddy’s property popped the coax right out of the bumper.
The next hurdle is how to prep the cable to recoil as the truck completes its turn so it doesn’t drag on the ground. I lucked out with finding out I was short in the grass, had it happened on the road my truck connection would’ve been donzo.
gator6
Nov 9, 2021
On the road, USA
I may have come up with a solution to having slack in my rearview cable issue.
Other than moving the jack to the bed, and bringing the cable down through the kingpin hole…which would be easier in the long run, had I put in a bit more time and effort.
Looking at my slide outs tonight I noticed they use springs to keep the slack from pinching the cables. I may ask a local dealer if I could get my hands on one before getting on the road next week.
Pat Prince
Mar 7, 2022
Anyone experiencing signal interruptions with extensions being used. My set up works fine for hours then losses the camera signal and says camera is unavailable along with a service required warning in the evic. I have the same set up most have used with a 10ft Farrah extension and bed relocation with no extension on that side. Sometimes it works for 1 hour, sometimes for 4 hours. Continues to work if you shut down and restart the truck.
99ls1tj
Jan 6, 2020
Does anyone know if this is an option for a 3500 regular cab? I see wired tow-mode camera and trailer camera wiring (no camera) by Mopar. Thx
Dlleno
Nov 13, 2021
Pls pardon the dumb question... the trailer Surround camera system comes with two cable lengths (module to 12 pin) . I've connected them together but can't get them apart! What's the secret...
QuattroCS
Jan 24, 2022
North Florida
is the red slider (unlock) as far back as it can go?
Dlleno
Nov 13, 2021
Yes its all the way back and i can see that the little hook (end of the red slider) is engaged when pushed all the way in. It feels like there is something else holding it, but I just can't see anything
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
If the red lock is all the way back, press down on the black release lever and wiggle them apart. It’s a weather sealed connector, so there is some suction resistance that makes them hard to pull apart.
Dlleno
Nov 13, 2021
Is that the black release lever?
Dlleno
Nov 13, 2021
Thank you that's what I needed! Took a small screw driver to actually lift the black release lever over that pin
gator6
Nov 9, 2021
On the road, USA
Yes! Having the same issue. [mention]22limited [/mention] are you having these too?
I flip the mirror down and back to reset, but eventually I’m looking at my 5er nose. I flip it down for 10/15 min and it may come back, sometimes not. While, just as you stated, sometimes it’ll work for hours…others just minutes.
I’m going to zip tie the connectors better to see if that helps this next haul, but so far it is a frustrating experience…albeit, great when it works!
gator6
Nov 9, 2021
On the road, USA
