I couldn’t say for sure. They may have recently cut out the digital rear view mirror from that group, and that build was one of them.Its just odd some of these windows coming out are $1590.View attachment 22211
On my poc it is indeed $1990
I have the connector already. The camera was reportedly junk68382504ac
I am just guessing but it might be because you have trailer surround view so it does not include the digital camera in the safety group. Here is what mine looks like. I also do not have the trailer tech group in case that mattersI couldn’t say for sure. They may have recently cut out the digital rear view mirror from that group, and that build was one of them.
I was in the same basket. limited Level 1 would kick out XN1 cameras and the other way around. Dealer said Good to go Sat. 9/18 and order went thru yesterday.As an update, dealer just sent an email stating that the unavailability of XN1 for the 2500 limited is a system glitch and they are working on fixing it, it should be available to order...
XH7 is all I wanted, but can see value in XN1. Backing a trailer, taking sharp corners or driving in a lot of traffic. Would be nice to see all around the trailer. But 4 wired cameras was too much to futz around with.So the XH7 I’d imagine would be perfect for my situation where I’m towing an RV.
Can someone give me a scenario where you’d use the XN1 system?
Since my build was supposed to have it and it was left off, trying to decide if I really need it or not.
They are two different “tools” with different uses. XH7 is the equivalent of glancing in your rear view mirror like you normally do. When you have the XH7 camera on the back of your RV while driving, you can look in your rear view mirror and see what is behind you.So the XH7 I’d imagine would be perfect for my situation where I’m towing an RV.
Or like me backing up into driveway thru a maze of trees-never had before, but hope it helps with blind side checking w/o an assistant handy.XH7 is all I wanted, but can see value in XN1. Backing a trailer, taking sharp corners or driving in a lot of traffic. Would be nice to see all around the trailer. But 4 wired cameras was too much to futz around with.
NoYeah, XH7 definitely, XN1 was willing to pass up over limited 1 pkg., but the last remaining question is if the limited 1 package comes with trailer tech stuff; does that include the 12 pin connector with driver module to run the camera setup in the future?
With xh7, and truck surround with trailer tech you should have adequate rear/side viewing. Will be much easier to retrofit multiple trailers as well. Xn1 would probably shine for the 102” wide 44ft 5th wheel camper that needs absolutly every view. Otherwise I cant see the trouble being worth it. Especially if you have multiple trailers that are smaller.
So in that case I'm glad I added it-even if it takes me a (long) while staring at a box full of cameras and wiring before I actually install..
