LateToTheParty
Didn't want to come
Every single one of them?I got these cheap lift kits, it is perfect for my truck especially when I'm using it for heavy loads.
Nice setup, what tire size and wheel size and offset?I did the 3/1 Readylift on my 3500. I also added Bilstein shocks, and have zero complaints about the lift... I too need to add the track bar. Which one did you install by the way?View attachment 3891
Spacer lift keeps the factory springs. I found 1” to be perfect for my needsAre there any options that don't involve softer springs like thuren and Carli? I find the front springs too soft as it is. The stock ride does not bother me one bit. Does anyone have feedback on the bilstein kit?
Just purchased the Bilstein coil and shock kit from Bilsteinlifts.com but won’t have it installed for a couple weeks. They have been out of stock on them but now have them again. I agree, frontend is too soft as it is.Are there any options that don't involve softer springs like thuren and Carli? I find the front springs too soft as it is. The stock ride does not bother me one bit. Does anyone have feedback on the bilstein kit?
Was this the 1 inch traxsda spacer?@woody284 i finally put the 1” lift on the truck. The garage door scratched the roof on the way out, lol
1” front/ 0” rear
285/75-18 (35”)
Still has ~7/8” rake front to rear
Hardest part was torquing the control arm lower mount bolts to 225lb after i did the alignment... because I’m a tiny man
View attachment 14707View attachment 14708
It was, sir.Was this the 1 inch traxsda spacer?
What size tire is this running? Looks goodReadylift 3"F/1"R lift, 20x9 Fuel Couplers with +1 offset on Nitto Ridge Grapplers. Zero rub. Still have to add the adjustable track bar to get the front the same on both sides. Love the ride and the look.View attachment 3402View attachment 3405View attachment 3404
Had it on my 18 2500 and it road much better than stock. I also had the dual steering stabilizer, aftermarket track bar and replaced the ****ty draglink fca recalled. I liked it so much I bought another kit for new truck but ended up with the tradesman powerwagon instead. I have kit up for grabs if anyone wants to pick up.Are there any options that don't involve softer springs like thuren and Carli? I find the front springs too soft as it is. The stock ride does not bother me one bit. Does anyone have feedback on the bilstein kit?
g to s is 7' 2" with this set up.
35x12.5/18 yokohama geolanders
18x9 wheels
3" front 2.5" rear lift - spacers
no air ride
Where did you find a 3 inch spacer?
Did you end up doing a track bar with the 1 inch? How do the shocks feel since the 1in doesn’t come with shock extenders?It was, sir.
I didn’t do a track bar. According to my trig calculations, the axle only shifted 1/4” with installation of a 1” front lift. Imperceptible to the naked eye, so I’m not even sure it moved that much.Did you end up doing a track bar with the 1 inch? How do the shocks feel since the 1in doesn’t come with shock extenders?
I’m really thinking of doing the 1 inch also and just getting the RC track at for peace of mind.
