Service Def System See Dealer message
Raidercat
May 4, 2021
Had the message Service Def System see dealer message pop up today while towing my camper home. Message stayed up for about 15-20 minutes then completely went away. Truck is a 2020 2500, 11K miles. I pickup it up Pre-Owned with 6500 miles on it. Since ownership for 1 month I’ve added 5 gallons of Platinum Blue Def and just did an oil change last week. Def tank is about 1/2 full. I’m still very new to diesel trucks and the def system and my question is should i be concerned or just press on and drive the truck as normal? The truck did not throw a check engine light and never ran funny or anything, temp was maybe 40 degrees outside.
easye515
Jan 4, 2021
If I remember when that happened to me, it went away a couple times, then went into countdown mode. You need to take it to a dealer so they can re-flash the computer.
Raidercat
May 4, 2021
Ok thanks for the info I’ll make an appointment.
Raidercat
May 4, 2021
Following up on this post, went to the dealer today. Truck had no codes and has been fine since that Def warning see dealer message. Dealer said go drive the truck lol.
DerKomisar
Nov 15, 2019
Mine did this yesterday. 2019 2500. Keeping an eye on it in case I need to get to the dealer. Has been cold here lately so I was hoping it was the tank freezing and a good thaw would help.
Raidercat
May 4, 2021
Hope yours is good to go. Thinking back my def tank had Platinum Blue in it but I did not know about checking dates being a newbie.........it’s possible I could have grabbed some old stuff and put in the tank. I found some super fresh Blue Def and dumped that in there yesterday staying with the theme “the solution to pollution is dilution” lol.
John Jensen
Feb 11, 2020
FYI
An Edge CTS3 monitor will show your DEF % and the command for Def.
I monitor both of those. When I put in Walmart DEF, it showed 34%. DEF is normally 33%
When I added a gallon of distilled water, it read 26%. The DEF sensor will alert at 22%.
Raidercat
May 4, 2021
FYI
Sounds like an investment I need to make thank you!
DerKomisar
Nov 15, 2019
Well the "150 miles to 5 mph" countdown started on mine. My OBD2 program reports a "pending" code P203E. Google says this is an erratic DEF level sensor. Seems this problem can happen when there is a large swing in temperature (exactly what happened Tuesday). The DEF tank can freeze and not thaw quick enough . It is described in TSB 18-034-21. Now I need to find a heated garage overnight; then do a reset drive cycle. Except getting a +39F day in MN this time of year is unlikely. Will try anyhow. At least the DEF tank and sensor are listed on the 5y/50k emissions warranty. Presently 37k on my 2019 2500.
DerKomisar
Nov 15, 2019
Well my truck has been stuck at the dealer waiting on this part for a month now. The service guy keeps saying the part is expected Monday and then it gets moved back a week. He now has a bunch of these trucks on the lot with failed DEF systems. I am first in line but the part keeps getting delayed. @RamCares can you shed any light on this situation? The dealership service guy seems like his hands are tied. What's happening? I would really like my truck back.
Darmichar
Jan 26, 2022
I work in this area on the machine side. The global chip shortage is causing back orders of a lot of DEF sensor/manifolds used in aftertreatments.
RamCares
RamCares Team
Mar 25, 2019
Greetings,
We would like to look into this situation further for you and see if there is any opportunity to assist. Please feel free to send our team a private message with additional details.
Rob
Ram Cares
Greetings,
Rob
Ram Cares
Make ram offer a DEF delete that would be the only helpful thing you can do!
sstoner911
Sep 28, 2020
FYI
John, is that part of your tune or is that something the CTS3 can do as a stand alone unit?
sstoner911
Sep 28, 2020
Yes! The first responder vehicles do not de-rate. They warn only! This should be available on the 3500s( I am biased) since they are used more often as commercial units.
Nothing like getting the countdown. And if you hundreds of miles away from anywhere - it could really suck! I got lucky and was still close to home, but I can tell you @RamCares if my wife had to sleep in the truck over night, FCA would not like her phone call the next day!
I have been told thats not true anymore the first responders will get the derate message too
John Jensen
Feb 11, 2020
Shawn,
Those are PIDs that the CTS3 pulls from the truck. Tuning only affects them if the tune turns something off. For example, if the tune turns off the DEF system, the CTS3 can no longer read % DEF, the DEF command or the DEF tank level gauge.
The tune on my 2016 1500 now turns off the DEF system. My 2020 3500 6.7 tune (emissions intact) leaves the DEF system working, which I like.
Riddick
Aug 12, 2021
Yorktown, VA
At least the 19-21 owners have the option to pursue aftermarket tuning to solve this. Everyone keeps claiming how the emissions systems are more reliable on the newer trucks but I'm not sold. The DPFs seem reliable but I read post after post regarding EGRs and DEF.
Here's to hoping someone cracks the 22 ECM.
There are deletes for the 22 already
John Jensen
Feb 11, 2020
Could you elaborate on your comment, "but I read post after post regarding EGRs and DEF."? I read a lot of posts over several forums. I know there are a lot of complaints about DEF consumption, but I don't remember reading much about EGR and DEF problems.
Appreciate it - thanks
