I installed the resistor, checked the setting "CBC Config I/O Usage-Connector A Pin 11: Hood Ajar Switch Signal Usage" to make sure it was set to 1k parallel resistor, then changed the setting "CBC Config I/O-Connector A Pin 11: Hood Ajar Switch Input Present" to Yes
But the hood ajar alarm doesn't go away, and of course it doesn't remote start due to the hood ajar alarm (with the EVIC saying remote start sequence cancelled due to hood ajar). When I change the Hood Ajar Switch Input Present setting back to No, the hood ajar alarm goes away but I still cannot remote start. The truck just chirps once and on the EVIC it says to depress the brake and push the start button as if I was about to start the truck normally. Am I missing a setting or something? Or could it just be that there's something wrong with my resistor connection? I have it spliced in to the wire on pin 9 of the XY110A connector (female side). At first, I connected one side of the resistor to the wire, then looped the other side of the resistor back to the wire, thinking that's how you do it (obviously I'm not too experienced at this!). Then I disconnected one side of the resistor and ran a wire from it and terminated it at one of the grounding bolts nearby. Neither way changed things with the hood ajar alarm or the ability to remote start.
I then just ran extra wire from the pin 9 wire to the ground bolt and changed the setting from "1k parallel resistor" to "500 ohm series and 500 ohm parallel resistors". Still no change. Maybe I'm not understanding things correctly, but I understood that either one of these methods should have worked.
Either way, my new hood latch is supposed to be coming in Dec 13 so I've basically given up on installing the workaround.
