Kunkernator
- Joined
- Aug 4, 2020
Hi all, new to the forum, as I bought not only my first Ram HD, but my first new vehicle! A 2020 2500 Tradesman with the Cummins diesel, 4x4 6'4" bed, upgraded with 8.4" uconnect.....
The only option it does not have, that I truly desire, is a remote start. My truck has a push button start and keyfob.
The dealer said it would be $700 to install a remote start, my question is, to get the factory remote start; what do I need to do?
Is it just as simple as buying and programming the new keyfobs with the extra key, and then having the truck Vin coded?
I am wondering what, cheaper options there are to obtain the factory remote start.
Thanks!
[mod: Solution info below:]
Late 2023 update: JScan can now program HD FOB's, known working GQ4-76T 5 button FOB here: https://www.ebay.com/itm/194308932824
AlfaOBD or JSCAN* setup:
Have dealer program OEM FOB or use JSCAN to program OEM or Aftermarket FOB
Thanks!
Security Bypass cable: https://www.kaodtech.com/product-page/security-module-bypass
OBDII reader: vGate vLinker MC/MC+ or OBDLink MX/MX+ recommended (See AlfaOBD thread for discussions on readers)
Hood latch connector and wiring info in @Jimmy07 post here: https://hdrams.com/forum/index.php?...dded-to-2020-tradesman-solved.2401/post-35045 Install and pin hood latch pin 1 to BCM C1 Pin 11, pin 2 to ground
Optionally connect BCM C1 Pin 11 to 1K Ohm resistor to ground if not using the hood latch
Using Jscan or AlfaOBD, set VehConfig 1 Remote Start Present = YesHave dealer program OEM FOB or use JSCAN to program OEM or Aftermarket FOB
