Yes remote start will work by just added the XBM sales code. They could not find the JKR sales code to add, but it worked after they programmed my new remote.This thread is amazing. Sorry for bringing it up after a month. But I did have a few questions.
My truck only came with 1 fob and the dealer will be ordering me another Fob.
I am wondering, I am going to call them on Monday and see if they can get me the fob with the tailgate and remote start, and I'd pay the difference between that and my 2 button remote.
Now, they will have to program that remote - and since I "NEED" a second key, I am wondering if I can have them do that for me and add the sales code for the remote start.
I tried to read this thread, but I have two kids bouncing around, TV playing Aladdin for the 34th time this week..
SO am I accurate from what I found:
My 2022 Ram 2500 Big Horn has the harness and wire at the hood latch.
I just need the sales code of XBM added - and the remote start will work or will I need something else on top of that?
And the sales code of JKR for the tailgate is not needed, as that seems to work right out of the bag. I also just installed the tailgate damping.
Any help would be helpful. It's awesome to see so many wiring diagrams, pin locations, BCM pins, etc from you guys. Where are you getting that info from???
By the way. I freaking love these trucks!!!!
Yep just need the sales code for remote start only the tailgate release code is not neededThis thread is amazing. Sorry for bringing it up after a month. But I did have a few questions.
I had a.really hard time explaining to them the gate will work once they program the fob. There was a lot of words exchanged and finally they did program it. They were so shocked it just worked that they call over couple salesman and technicians to tell them about it.This thread is amazing. Sorry for bringing it up after a month. But I did have a few questions.
I had the same issue when i had the dealer enable the remote start they insisted my added switches in the fob would not work (even though i proved the gate release worked) they also said i needed a module and other parts for the remote start to work. In the end i told them they had nothing to lose they were getting paid either way. In the end they were flabbergasted when it worked and they were wrong they were not very happy after i laughed in their faces and said they were crooks for trying to sell stuff that was not neededI had a.really hard time explaining to them the gate will work once they program the fob. There was a lot of words exchanged and finally they did program it. They were so shocked it just worked that they call over couple salesman and technicians to tell them about it.
It’s 2-3 option. But the setting you’re referring to (auto on driver comfort CSM) is for the heated/ventilated seats and wheel to come on above 77°/below 40°.So I finally got another dealer to program the fobs and got my remote start to work. Bonus is the remote tailgate open works to, with nothing extra to do. I did get the auto climate on with remote start to show up on the uconnect 5, does anyone know what setting for the cust. Program 1 should be at? Options on alfaobd are 1&2 option or 2-3 option. Truck is a 2022 3500
Thanks. I didn’t do anything with the CSM one. The only other setting I turned on was the cust. Program 2 changed that to yes then it showed up on the screen.It’s 2-3 option. But the setting you’re referring to (auto on driver comfort CSM) is for the heated/ventilated seats and wheel to come on above 77°/below 40°.
I added this to my 2019 2500 Big Horn and mine did not have the proper hood latch. I had to order the hood latch with hood ajar sensor, then run 2 wires to the harness underneath the fuse box where the wires from the BCM terminate for the hood ajar sensor to operate. You could also run the wires directly to the BCM but I wanted it to be more "factory".SO am I accurate from what I found:
Answering my own question, based upon info I found elsewhere it shows 0.35mm, which is 22 AWG.I don't think it was mentioned earlier in the forum - what AWG is the wire for the BCM?
22 Tradesman 2500, no hood switch...So, can I just T-Tap or Posi-Tap to ground with a 1k ohm resistor inline at C1 pin 11 or at pin 9 of the gray connector? Or does this wire need be cut and grounded?To add to my reply above: another option if you don’t have the hood latch and wiring- the hood ajar sensor wire is most likely present at the BCM connector C1 pin 11. You can just ground that wire with a 1k ohm resistor, and the BCM will see the hood as always being closed. Just throwing that out there if one weren’t concerned about installing the correct latch and wiring.
Just connect the wire to ground, no need to remove it from the connector.22 Tradesman 2500, no hood switch...So, can I just T-Tap or Posi-Tap to ground with a 1k ohm resistor inline at C1 pin 11 or at pin 9 of the gray connector? Or does this wire need be cut and grounded?
I am so excited. Finally ordered and got the key today! Heading to the dealership this afternoon where my buddy works to program the key!
ordered: https://www.carandtruckremotes.com/2022-ram-2500-smart-remote-68374994ab.html#yswCart
