My apologies for going off topic thought it was art of the check listYou guys are WAY off topic talking about tire pressures in this man's thread.
Yes its included in the checklist but there are a couple dedicated threads on the ole tire pressure topic that may yield better results for you than rehashing them here.My apologies for going off topic thought it was art of the check list
Thank you appreciatedYes its included in the checklist but there are a couple dedicated threads on the ole tire pressure topic that may yield better results for you than rehashing them here.
Recommended Tire Pressure dropped from 2017 2500 (20s) to 2022 2500 (20s)???
I traded in my '17 2500 Laramie 6.4 on OEM 20s for my '22 2500 Laramie 6.7 on OEM 20s and noticed the tire pressure door card says 65 PSI all around. I'd swear my '17 (did have 5th wheel tow prep package - my '22 does not) was 80psi all around. I saw that my truck was delivered with >80psi in...hdrams.com
Ideal tire pressure for the 285/60/20 tires
I know this is info is all over the place, buried in different posts, so forgive me for starting a new post. I just wanted to have it in one place so someone can search and find it easily in the future. That said, what have you find the best tire pressure for these tires (yes, I am...hdrams.com
I think the mud flaps are per state, as some states require them (TX being one, so dealer installed them).Anyone know if the front license plate bracket is included with all trucks? My EL has it listed as delete so I am unsure if I should expect it placed in the vehicle.
Are mudflaps typically installed on all DRW's? Or is that a state specific requirement?
Where is the def level indicated?
ThanksThis may be trim level dependent and don't recall it on the list, but my truck had the electric pedal adjustment.
Again maybe trim dependent, mine has the exhaust brake adjustment that could use to be checked to make the it can be adjusted.
Thank you for clarifyingI have a truck ordered through MD in Louisiana. This is a “no front license plate” state.
The front plate is automatically deleted unless you tell the dealer that you want it.
I have to get one for Missouri. They are free when ordering, but the dealer will charge you for it (about $30 in my case) if not “ordered” with the truck
Winch set up, and that you have the controller, would be the only PW specific things I can think of. Unless you want to test locker functionality as well.Updated a few things on the checklist/guide.
1. Are there any Power Wagon specific things or items that it would be helpful to know?
thanks will update. do you have a part number for controller by chance?Winch set up, and that you have the controller, would be the only PW specific things I can think of. Unless you want to test locker functionality as well.
Yep, could probably go about trying to see if that too works if one sees fit.Don’t those still have electric sway bar disconnect?
I will add that thanksSomething to check if you have the 5th wheel prep:
I found the mount points on the frame were not centered in the holes of the bed. Basically, the bed needs to move about a 1/2 inch forward on the frame rails. It should be a fairly simple process to loosen the 8 bolts underneath, then muscle the bed into a better position, then retighten everything. I'm letting the dealer take care of it next week.
Bed vs cab is mainly the forward/back axis that needs to adjust. Also looks a little bit to the left.I will add that thanks
Is your bed currently misaligned with the cab too?
Awesome, all good to know info thanks!Bed vs cab is mainly the forward/back axis that needs to adjust. Also looks a little bit to the left.
This is also seen at the gap between the bed and cab. The rubber piece has some space on the left side that probably shouldn’t be there.
