How many grounds are to be checked? Is there a difference on the number between Hemi and Diesel?
I don't know specifically. If you want to be that macro detailed, I'd say check under the hood of one and add that to your list.
Unfortunately, I don't have any really convenient nearby. The lots here are still pretty bare. A few 1500's and a couple barebones chassis and tradesman's. But since none of those are what I am getting I have no idea if this is a common thing between them all.I don't know specifically. If you want to be that macro detailed, I'd say check under the hood of one and add that to your list.
I found 3I can’t say specifically either for the ‘22, but I want to say the 3rd Gen has 3, and if that carries over to the 4th Gen I wouldn’t guess it’d change on the 4.5
Awesome thanksI found 3
What did you set them at for the drive home?There is a reason that tire pressure is something to check.
Wondering also if you noticed if the center section of the rear inner wheel liners were there or not ?What did you set them at for the drive home?
The factory wheel liners do not go all the way up from my understanding.Wondering also if you noticed if the center section of the rear inner wheel liners were there or not ?
I have heard both coming with and not and some dealers taking care of the issue and some not so was curiousThe factory wheel liners do not go all the way up from my understanding.
It was taking forever to let the air out (I have a gauge that has an air release button), so I only brought the front down to 73. The rear outside I brought down to about 85. The rear inside I couldn't do anything about since I had no way to get to them. Their Service department had to shut down early today (small-ish dealer, so not a lot of techs in general), so no one there to take care of it. I need to buy some valve extenders and will set it when I get those.What did you set them at for the drive home?
- Fuses fully seated.
At least they're consistent!About 90% of my fuses were not fully inserted. When I pushed the first one and it clicked in, I called the salesman over to show him. He saw me push in just about every single fuse. I think there were only 3 or 4 that were fully seated.
Anything else you would like to note as DRW specific? Or Diesel Specific?It was taking forever to let the air out (I have a gauge that has an air release button), so I only brought the front down to 73. The rear outside I brought down to about 85. The rear inside I couldn't do anything about since I had no way to get to them. Their Service department had to shut down early today (small-ish dealer, so not a lot of techs in general), so no one there to take care of it. I need to buy some valve extenders and will set it when I get those.
Two things:
1) The check list should specify that for a dually, the air pressure gauge needs to have the long shaft with two ports, one facing backward 45 degrees.
2) Again, for a dually, purchase valve extenders ahead of time, or request the dealer install them
3) If your truck has TPMS, then you can check the pressures there, but you will still need a way to let air out if needed.
I would also be interested in a list of additional items that were with whatever packages you got. I am a little bored at work and can add all that in a list at the bottom.
Appreciate the info very good thank you!It was taking forever to let the air out (I have a gauge that has an air release button), so I only brought the front down to 73. The rear outside I brought down to about 85. The rear inside I couldn't do anything about since I had no way to get to them. Their Service department had to shut down early today (small-ish dealer, so not a lot of techs in general), so no one there to take care of it. I need to buy some valve extenders and will set it when I get those.
Two things:
