That is not the correct one. HDs use white for both can ihs and can c. The 5th gen 1500s use that green one for their can ihs. All you need to do is shave the key way off of the green one that protrudes on the bottom and it will fit-Does anyone know if this is the correct STAR CAN IHS connector? It does not seem to fit the 2500 so maybe I need to replace it with the white version?
I’ve got short fingernails, so I use a jewelers flat head and push in on the tab and up at the same time to pop it out of the block-I'm struggling trying to remove the star can ihs connector from the terminal block. I can't seem to figure out how they are removed? I'm pushing the side pin towards the connector and can't seem to get it loose.
Any guidance would be appreciated.
This is the best thread i can find on these steps. I picked up a set of take offs from someone, but didn't get the controller or harness. I don't care for the steps to be routed through the radio and ill even wire it through anywhere for a signal wire. I just want them to go up and down when the door opens, with spending little to no money getting more parts. My we question is, with the wiring. Are the steps grounded through the actual mounts to the cab? And are the signal wires 12v or less I see they run through a resistor and don't want to fry my step motor. Even if i have to wire them of a manual switch in the cab that's still fine with me. I just dont know what to send to each wire on the step.
Hey all I have an issue with my 2020 Ram 2500 side steps. They only deploy half way then retract back in. Does anyone else have this issue and is so what was the fix? Thanks.
I have an appointment on Monday I’ll get back with you on that after the appointment thanksI apologize for the trouble, @tozz43. If you decide to address this with your Ram dealer, please do not hesitate to follow up with us via private message for further support through that process!
Mark
RamCares
@tozz43 If you would not mind can you let me know what you find out? I just experienced that issue yesterday. I've also experienced an issue where they were deployed and then won't retract, they try to retract 1/2 way and then stop and fully deploy again. I did eventually get them to retract fully after a few door open and closes. They seem to be working fine now.Hey all I have an issue with my 2020 Ram 2500 side steps. They only deploy half way then retract back in. Does anyone else have this issue and is so what was the fix? Thanks.
Mine don’t come out sometimes. Have not taken it to the dealer. Please let me know what the dealer says. ThanksHey all I have an issue with my 2020 Ram 2500 side steps. They only deploy half way then retract back in. Does anyone else have this issue and is so what was the fix? Thanks.
I have this issue with my passenger side one. I haven't had a chance to get anything gummed up in them yet, but I was going to hit it with the hose and see if that helps.Mine don’t come out sometimes. Have not taken it to the dealer. Please let me know what the dealer says. Thanks
This post is in reference to the deployable running boards. Ok so I went to my local ram dealership at 10:30 am today. I was told to leave my truck there all week and it might be seen Thursday or Friday. I asked why, I was told they have 50 other vehicles on site that have to been repaired first. I asked why would you have me drive across town for an appointment knowing your not even going to look at my truck all week. I was told its their policy. So I brought the truck home. It saddens me that I spent 75000 on a new truck that I cant even get it looked at.I apologize for the trouble, @tozz43. If you decide to address this with your Ram dealer, please do not hesitate to follow up with us via private message for further support through that process!
Mark
RamCares
Anyone have any advice on what I should do next?
