Hello,
This is a wonderful thread. Sounds like
@Jimmy07 ,
@johanh13 have been successful installing the Mopar Power Running boards on their 2019 2500's. I just picked up the parts from the dealership and was told this was the kit I needed. The part number is 82215287AC. I was told by the dealership this kit would fit my new 2020 2500 Laramie Crew Cab. The kit came with two power running boards, the BCM, 1 wiring hiring harness to connect the two boards and power to the BCM and one to connect the BCM to the CAN bus and ground. The instructions seem pretty simple, however the instructions show that there should be bolts on the vehicle to mount the boards and there are no bolts. I'm wondering if others ran into this and if there is a kit for the bolts.
BTW - I needed the truck with specific options and could not wait to order one, so I'm hoping I can add these since I got most of what I needed. With the COVID shutdown of the assembly plants the current supply is very limited.
Also in all of my searching on that part number it only appears associated with a RAM 1500 so now I'm wondering if I this will work at all.
Here are the sub parts on the kit in case anyone is interested
Power side step LT (Crew) - 68275813AB
Power side step RT (Crew) - 68275812AB
BCM - 68275941AD
Thanks for any help!
