An update on the new fender flares, I had ordered a set of 2019/20 Power Wagon oem fender flares about $165 including shipping.
These are nice, wider than the stock oem painted type flares,
Since my truck didnt come with these and on the new body style the fenders have holes to clip these in, I used a set of diagonal cutters and cut off all the push in clips and a few molded parts designed to align the fenders.
Added a piece of 3m double sided molding tape on each white clip . I had to remove all the inner fender bolts 8mm socket I think, removed the lower moldings.
Bolted each one and pushed the upper fender so the tape sticks. They fit great , on the rear fenders you will need to add a two screws a few flat washers and nut since the flares have these holes and truck already has the holes..
Beginning to end about 2 hours to install, it was hot and i went slow, I think they look great and will help out when I level the truck and go to 35x12.50's
