Fender Flares?
Jan 16, 2019
What do you mean by put out the stock looking ones? You can buy the stock OE flares, they are like $40 a piece.
Right front: 6MS44TZZAC
Left front: 6MS45TZZAC
Right rear: 6MS42TZZAB
Left rear: 6MS43TZZAB
I looked them up for my truck, which is silver, and then using a VIN for a red truck and they were the same part number. I fairly certain you'll have to get them painted to match.
Are those the flat ones (usually color matched) or the power wagon ones with the indent towards the top (usually black)? When I look them up I see two P/N's
For the front left
6MS35GXHAC
6MS45TZZAC
Cowboyup1494
Oct 24, 2019
As someone else stated above the 19s require holes in the the fenders to accommodate posts/pegs or clips that are part of the flare. So it’s obviously not possible to use the direct part form say a Laramie. In the past (2018s) there was no difference in the fender and you could take the flare and throw it on a tradesmen if you wanted, which I did with my 14. Now it seems that the 18 flares will fit the 19s according to others but they won’t accommodate the new plastic trim along the bottom. Mopar does have a flare with the faux bolt on look that some may prefer(I do not) and those do work with a 19 and do not require additional holes in the face of the fender but do accommodate the new trim along the bottom.
so really I’m looking for the oem look without needing extra holes and able to mount them without removing my plastics along the bottoms.
Jan 16, 2019
Really? That's interesting, I was actually looking at getting the new power wagon style flares for my 2017 but if that's the case I guess I won't be doing that. You can't just cut off the pegs on the '19 fender flares?
Cowboyup1494
Oct 24, 2019
I suppose that could work. Hard to know without having them on hand to check out. Looked like a guy on another forum had some luck doing that with a 19 1500 though. I’d just be worried about getting a snug fit.
Hopefully someone else will give it a try and inform us all!6A23F422-801A-438F-8430-306A8B4FD82B.png
Hnines
Dec 1, 2019
Just got them in from the dealer took a long time for some reason, got the flaps too. Here are some pics. I love them and the fact they bold on so quickly I may take them off annually or even more to clean up anything stuck behind there. Got them for rot protection not really looks but boy they look great.
I’m thinking about going with these as I like the pocket flare look. Couple questions though......
These OEM ones look like they might not stick out as far as the Bushwacker pocket flares, does that seem to be the case?
Can these OEM flares be painted to match the truck color?
Any place to purchase them cheaper than the dealership?
Ttrice
Jan 3, 2020
I did find flares. A guy near me had some of the 2018 flares from Mopar, brand new. I put those on vs the new flares by mopar that have the faux bolts showing. The only issue was the existing trim molding on the back side of front wheel and front and backside of rear wheels had to be removed. Ram changed the wheel well molding from 18 to 19. I tried to modified those new moldings to fit the old flares but was too difficult to get cut correctly, so I just removed the moldings. Other than the moldings, the flares fit great and match the body contours. I also put some paint protection tape under where the flares tape to the fender to avoid the paint wear that many talk bout. This worked good, had a couple of spots were the flare separated from the body when I ran thru car wash first time, but restuck to fender and no issues since, but I didn't wipe down protective tape before flare install on top, I would do that. Just putting pressure a on the flares to restick again worked fine, without a repat issue. I think the way the flares install as you mount first and then pull tape and stick, and the amount of pressure from mount screws plays into this., if you are anal about this stuff like me. So far, no separation and I really like the look and fit.
Did all the holes line up or did you have to drill new ones?
fao1
Apr 10, 2019
So I’m on the hunt for flares as well. I’ve ordered a 2018 set as it seemed like the best option out there since I didn’t want the rivet look of the ONLY style mopar is offering. But I’m having second thoughts now as I’d really like to keep the plastic trim along the bottom, especially with my 8ft box.
Has anyone actually got a set of the new 19 flares? I’d also like to have them painted to match body. View attachment 1677
I just cut it flush for rock guard
everything fit good for the 2018 fenderflare for me except the front fender on 19 dont have that curve near the light so i just double layer the moldingtape and push hard with heat and that thing stick and took place!
downunder
Dec 13, 2019
Hello from Australia. Will be ordering a new 3500 Limited soon and I am looking at fender flares and mud flaps. Does anyone have any pictures of a 19 with the Mopar 'pocket style' flares and +18mm offset wheels as that is what I am thinking of doing. Not sure if they will cover a wheel with that offset, maybe I will have to go with the Bushwacker pocket flares as they seem a little wider. Does anybody know the respective widths of the Mopar and Bushwacker flares? Thanks for your assistance.
Hnines
Dec 1, 2019
My truck is getting leveled, 20x9 wheels with 35x12.50's and the new OEM pocket style flares paint matched right now. Fender flares are supposed to be installed on Monday. I will report back with pics once they are installed, for those of you who are requesting info on the new OEM flares.
MikeXM
Nov 30, 2019
Yes, post pics! Thx
Hnines
Dec 1, 2019
Here’s some pics of the Mopar OEM pocket style flares for the 2019’s, paint matched. Just got them installed today.....
DHaus
Jan 3, 2020
York, PA
Looks great. What offset on the wheels? Do they stick past the flares at all?
Thanks
MikeXM
Nov 30, 2019
Looking good painted.
On my 08, wheels were also 0 offset and I installed the Bushwackers, which are a bit wider than OEM fender flares. Still, it was not enough to protect paint and had to add mud flaps too.
BravoZulu
Jan 17, 2020
Hello Fao1
Can you provide the part# on the flares you bought for truck?
Those are exactly what I’m looking for
I missed the part# if posted previously
Thanks For Sharing
Wrayzor
Jan 16, 2020
The Black Widow flares are aggressive but only sold as a whole truck package to dealers.
