kpecks
- Joined
- Nov 27, 2021
Hey! What bezel is everyone using? did anyone figure out the most effective means of routing cable? Thanks in advancve.
Nice! Was literally just reading another post you made. You ever decide which route youre going with? Straight to the mirror? Or try to rig it off the cab camera connection?I picked this up to try based on another members suggestion. I’m waiting on the camera and cables to come in and I’ll be able to get it all connected.
I bought my son a 3d printer for Christmas. I’ll be half tempted to try and make something to work if this housing doesn’t fit. Can’t be that hard right?!
Rear View Camera Cover 2018 Jeep Renegade 5UX73LXHAA / 735591063 2015 - 2020
I was just going to run an extension from the 3rd brake light location down and then back to the topper. It won’t be often that I remove the topper to haul a 5th wheel, if we even go that route for a new camper. So I decided to go ahead and run the cables to a splitter under the rear seat. Below are the cables I purchased. I picked up a simple coax splitter on amazon for $8. I will have a 6’ cable extension connected to the new camera on the back of the topper and connect that to the main run to the splitter so if I need to remove the topper, I can just disconnect and stuff it in the post hole or something. Hopefully it all works according to plan! I should have it done next week. I plan on running the cable to the camera thru the 3rd brake light area/hole on the topper. I’ll post pics up when I get done with the install.OEM camera Genuine Mopar Camera 68448640aaNice! Was literally just reading another post you made. You ever decide which route youre going with? Straight to the mirror? Or try to rig it off the cab camera connection?
Here is V4 and hopefully the last revision! I will print the final functional product in PETG or ASB and probably coat w paint/uv inhibitor.
V4: I added a cord channel, adjusted and widened the bottom contour and adjusted the depth of the lens port. As soon as things dethaw this morning, I’ll get it mocked up and see how everything fits. The camera fits in there really nice with very little movement so my plan is to put a small dab of epoxy or silicone and call it a day.
If anyone is interested, I’m taking orders!
It appears this is for mounting on top of the roof/cab, yes?
For mounting on my pop up camper - either on the back wall or near the license plate - I think I need a front mount.
Love your engineering though!
I got a housing and cable from this outfit to relocate my camera. Kind of pricey but works well.It appears this is for mounting on top of the roof/cab, yes?
2019 + Ram 360 View Camera relocation kit w/o camera Part # 250-8665
M&R Electronics Inc. specializes in automotive electronic repair. We offer: car radio repair, bluetooth handsfree car kits, backup camera repair and much more. We also offer thousands of electronic car parts and auto accessories.www.mnrelectronics.com
I have a 2020 with the 360 surround camera. I pretty sure the non 360 camera is different and is a different housing. If you look around on that site you will find the other housing kit as well.
Thanks.
I'll contact M&R and see if they can assist.
That could work so long as the angle of tilt gives you the view you need for your rear view camera. The Digital rear view camera is different than the backup camera. The digital rear view cam needs to be almost parallel w the truck, not pointing down at a 30-45* angle. Also, the rear view cam isn’t a wide angle cam, although I wish it was or maybe find a replacement. In our motorhome, the rear camera is super wide and mounted nearly 13’ off the ground so I can see everything behind me.pricey indeed - but certainly the mounting solution I'm looking for.
so the camera in the center break light assembly for the digital rear view mirror would fit and mount in this housing?
thank you!
Yes! Unplug from the back of the bumper connection. It is a fakra connection. Get two 6’ fakra male to female cables and you’re good. This is how I have mine set up and it works perfectly.I have a ‘22 with the digital rearview and trailer rearview connection. I’m thinking Inshould be able pull the plug out of the bumper and use that connection for a camera mounted at the third brake light in the truck cap. I’d have to gain entry into the bed from the bottom side, run cabling to the top-rear of the cap, then figure out a way to mount the camera in or near the shell brake light.
Trying to figure it out quickly because I have a tonneau cover on order and would cancel that/switch to truck cap if the rearview camera would still be useable.
