TinGoatTravelers
- Joined
- Apr 24, 2022
Got it - I think i get what you’re saying.You don’t tap into anything on the 3rd brake light on a 22. You simply disconnect the cable behind the bumper connection and plug in a fakra extension and run to your camera on your topper. The cable that connects to the bumper housing is already equipped with an o-ring and will perform fine as is.
Don’t know if you know, but a few questions on that Mopar camera on eBay (which is much cheaper than the official kit (camera, mount, and cable) for the RV rear view:
1) does it have the right field of vision - the same as either the CHMSL or the camera used for the RV tow view?
2) are you aware of a cable that could connect it to the bumper input of the 2022’s? It is RCA-like as you mention, I’m not sure exactly the right naming convention - but I’d love to be able to plug in either the RV camera or a topper camera for rear view in the same socket than have to disconnect the fakra to connect it behind the bumper
3) does your mount work with it in either vertical or horizontal position - meaning - not sure if I would mount it to the top of the topper (most likely) or lower, perhaps even to the window, which would be a different camera orientation.
Thanks for any additional insight you have!
