Thank you. I will give it a shot. Not sure where I am going to find a road with no stripes but I will look around. Did you mean “no visible strips”? I had heard in other threads that it needs some visuals. Just checking.
Sorry that is text to speech. You want lots of visible things. Stripes lines, trees, etc.
So make sure you go into Alpha OBD, connect to your body control, module, change its model year to be at least 2022. Then disconnect from the body control module and connect to the cVPM. On the status page for it, read the codes, clear the codes, then just go to the screen for camera calibration start rolling at about 5 mph and then start the calibration. After that is done disconnect in the software, reconnect, codes, clear codes, and then do the next camera rinse repeat. I don't know why that works, but it does
