Here’s the fun stuff - to calibrate the cameras using ALFa OBD - connect to the Radio - then read/clear codes (it will have codes every time) then go into CVPM - and have the surround camera active on your radio (even though it will be a black screen). Then back in ALFA under CVPM - do the calibration for only 1 camera at a time - but don’t start the test until you are rolling in a straight line at about 3-5 MPH.
After each camera is done, disconnect from the Radio, reconnect, clear codes, open Surround Camera on your 12“ display, select CVPM - pick the next camera, start rolling, start test. Your UC5 screen will go to a green thing with a wheel, and a 4 arrow pattern…. I recommend doing the Left and Right cameras first, then the front, then the rear.
So the order of operations is:
Open Alfa, connect to a Radio. Choose CVPM - click Status/Faults - Clear Codes - Click Active Diagnostic - Choose CVPM Service Calibration - Select Individual Camera - Do Not Start Yet wait until:
Then, on truck - select Surround Camera, roll at 3-5 mph in a straight line then,
Click Start. After the camera is done, disconect from the Radio in AlFA using the Start Menu, and repeat for the other 3 cameras.
