RickPatterson
- Joined
- Jun 26, 2022
I succeeded in adding building the camera to connect to the digital rearview mirror. I installed one on my 24' Cargo Trailer with the connection on the bumper and installed a second camera on my 40' 5th Wheel with the connection in the bed next to the factory trailer connection ports. I tried a variety of methods and finally settled on using RG-58 coaxial cable with smb screw connection ends. If you take the chimsl camera off the cab and get the part number for the replacement camera only as another member suggested you can order it from BAM Wholesale Parts
You will need this adapter to connect to the truck once you unplug the proprietary jack on the bumper: (From Amazon)
If you want to set it up for a 5th Wheel you'll need this item to go from the back of the bumper to the trailer jack inside the bed of the truck:
If you don't need the 5th Wheel connection you can just drill the plastic bumper and install a bulkhead adapter on the bumper. I ordered a variety of misc. parts and connectors from Amazon as follows:
Here is the only disappointment I had in the ordeal on the truck. No matter what kind of splitter I tried weather it be smb or Fakra the system will not recognize the trailer camera. as long as no splitter was used it works perfectly. What this means for me is that I have to crawl under the back bumper and switch the adapter to the bumper or the bed connection depending on what trailer I am pulling. Where I initially placed the bumper bulkhead that meant lowering the spare tire every time I had to switch the connection so I installed another bulkhead adapter in the license plate light on the bumper. This is off to the side where I can reach it without lowering the spare.
For the 40' 5th wheel I ordered a 65.6' smb cable: (Amazon)
and for the 24' cargo trailer I ordered this cable from Amazon:
I hope this helps someone out there trying to do what I did.
The cameras work perfectly. When you put the tow vehicle in reverse the cameras look down when you are looking through the trailer cam.
68448640AA | Camera | $97.38 | 1 | $97.38 |
Tecreddy Fakra Z Male to SMA Male Antenna Adapter Cable 12 inch Car GPS Navigation Car Stereo FM AM Radio Sirius XM Satellite Radio DAB Digital Radio 4G LTE Telematics | $6.99 |
SMA Extension Cable RG58 6.6ft(2M) TUOLNK SMA Male to SMA Female Coaxial Cable 3G 4G LTE WiFi Antenna Wireless LAN Low Loss RF Coax Assembly Cable CB | $8.99 |
Ordered | Price |
1 of: BOOBRIE 10PCS RF Connector Accessories Protective Cover SMA Dust Cap SMA Coax Cap Have Chain for SMA Female Jack Adapter Connector Nickel-Plated | $14.99 |
1 of: BOOBRIE SMA Socket Connector SMA Female Bulkhead Connector SMA Panel Chassis Mount Connector SMA Female to Female Barrel Adapter Antenna Jack Adapter for Wireless LAN Device Coax Cable,etc Pack of 10 | $13.99 |
1 of: ALLiSHOP SMA Connectors kit 18 Type SMA RP-SMA Adapter Plug and Jack Straight and 90° SMA Connector Goldplated Brass RF Coax Connectivity Set for FPV Antennas Radio Baofeng Yaesu IP Camera Project | $12.96 |
SMA Extension Cable RG58 65.6ft(20M) TUOLNK SMA Male to SMA Female Coaxial Cable 3G 4G LTE WiFi Antenna Wireless LAN Low Loss Coax Cable CB Radio | $24.99 |
SMA Extension Cable RG58 TUOLNK SMA Male to SMA Female Coaxial Cable 3G 4G LTE WiFi Antenna Wireless LAN Low Loss RF Coax Assembly Cable CB Radio (49.2ft) | $18.28 |
