My thoughts as well. Two weeks before they can see my truck and I doubt they will fix it correctly. We'll see. It doesn't really affect drivability when empty, but I can't tow a trailer with it right now.All the same codes I had when my EGR valve was acting up
My 2019 Cummins 2500 has a terrible “grinding” noise either from the converter or the tranny when your driving it through town at a steady 30mph. Have had it to the dealer twice and they tell me they can’t recreate it♂️ I was told to drive it until something breaks then they will know where to lookWell, I picked the truck up this afternoon after my transmission valve body recall was completed. As soon as I left the lot and came to my first stop sign, the truck feels like the torque converter isn’t unlocking at about 5 mph while coming to a complete stop. The whole truck shutters, lunges forward and trans is rattling until almost completely stopped. Anyone experience this? Just one more thing to add to the list... it’ll be going right back in first thing in the morning.
My 2019 Cummins 2500 has a terrible “grinding” noise either from the converter or the tranny when your driving it through town at a steady 30mph. Have had it to the dealer twice and they tell me they can’t recreate it I was told to drive it until something breaks then they will know where to look
That’s FCA/Ram for you. Par for the course. Sad
Have the exact same truck that is doing the exact same thing: PO299 CEL with no drivability issues. Started over 1,000 miles ago. Code has disappeared twice on its' own and I cleared it twice only to have it reappear within a day. Have not been into the dealer yet. Is there really a dealer re-flash to fix this? Any other solutions?Hey guys. I bought my 2019 Ram 2500 Cummins about a year ago brand new and it currently has ~18,000 miles on it. In the past 3 weeks it’s been at the dealership twice for a check engine light that is giving a P0299 turbo under boost code. The truck is completely stock with zero mods. The first visit to the dealership they performed the “Emissions performance Recall” by re flashing the PCM with the update and they said this would correct the issue... 1 week later the check engine light is on again for the same code. Now I’m being told that FCA is aware of the P0299 code and are working on a new update for it. I’m also noticing that in the mornings when I first drive the truck, if I accelerate from a stop with ~5% throttle to take off there seems to be a stutter or almost like it’s not getting fuel until I step on the peddle further. Has anyone else heard of this or had the same problems? Having to continuously leave my truck at the dealership for a week at a time this often is becoming very frustrating. To add to the frustration, they are stating they have NO loaner vehicles available while I wait... any input is appreciated.
After a couple of visits to the dealers and a reflash I still had the code. I’m not sure if this was it or not but I changed the air filter, cleaned the egr valve and replaced an oil soaked ccv filter and the truck has been fine since. I hate to jinx myself but it’s been about 27k miles and the truck is running fine.Have the exact same truck that is doing the exact same thing: PO299 CEL with no drivability issues. Started over 1,000 miles ago. Code has disappeared twice on its' own and I cleared it twice only to have it reappear within a day. Have not been into the dealer yet. Is there really a dealer re-flash to fix this? Any other solutions?
Do you have an aftermarket intake or even a non mopar air filterMy 2019 with 33k is having same issues. CEL, poor mileage and very slight stutter or miss at low speeds.
Brought it in to dealer for the CEL and they scanned it....showed P0299, under boost.
I'm tempted to throw parts at it and have them change the CCV and clean the EGR like someone said above.
Anyone try this with any good results?
I changed the air filter with a fleet guard but was under the impression this was the same as the Mopar? Maybe I'm wrong?Do you have an aftermarket intake or even a non mopar air filter
I think the fleet gaurd is fine i know the cheaper ones are an issue thoughI changed the air filter with a fleet guard but was under the impression this was the same as the Mopar? Maybe I'm wrong?
I changed the CCV, I cleaned the EGR. The EGR is totally different than the previous 6.7's but really easy to get out, clean and inspect. No help. It then progressed to an EGR code as well. No fix from me dealer. Sold the truck back to them last month. Good luck.My 2019 with 33k is having same issues. CEL, poor mileage and very slight stutter or miss at low speeds.
I feel like this thread is gonna make me get rid of this truck.GUy on another thread said he throttle body has gone bad and was getting the same code. Sounds like it was intermittently shutting causing the low boost signal.
Or put it on a weight loss program. Had a stuck EGR valve with only 3000 miles. That got taken care of quite easily without any visits to the stealership.I feel like this thread is gonna make me get rid of this truck.
interesting...I guess a throttle body/valve is better than a turbo actuator or something worse.GUy on another thread said he throttle body has gone bad and was getting the same code. Sounds like it was intermittently shutting causing the low boost signal.
