Well hang on, now I seem to recall that someone said the UC5 trucks were coming with the TIM already installed (though that goes against what Ram has been doing for options).
So let's check before you order parts you don't need. If you're up for it, you might want to pull the headliner and look. I imagine it's also possible to "see" the TIM using AlfaOBD.
Anyone have any info on this?
Ok so update from my last post. After your suggestion to go check to see if I had the headliner module….I did and found out I did not have it. So I ordered it and the small pigtail harness to hook it up. Installed it today and attempted to sync the trailer to my truck. And I was successful on the first attempt!
In the end I had to purchase the headliner module and the small connecting harness. The bumper receiver (and the cab and chassis extension harness), turned on the option using alfaobd and all works as it should! I would not have been able to accomplish this without everyone’s help and input! Thanks!
I do have one more question and don’t know if there is a thread covering it (haven’t found it at least) but in the trailer setup page on my screen there is a selection for “trailer navigation” when I select it it takes me to the navigation page however it’s blank / doesn’t load the map. Is there a item to turn on in alfaobd to allow me to setup height and length of rv to take me on “safe routes” or what is this selection for?
