Ok, I've read through this thread several time and have found the BCM Settings for the LED Reflector headlights but not for the LED Projector lights. If anyone has them handy would greatly appreciate it. Also do I need to add a fuse for the C6 28 connection for Jimmy's headlight harness.
The fuse for C6-28 is F103, and should be there.
This is the list of settings to change/ verify:
CBC Features: LED Front Turn Lamps Present- Yes
CBC Features: LED Low Beam Lamps Present- Yes
CBC Features: LED High Beam Lamps Present- Yes
CBC Features: LED Front Park/Marker Lamps Present- Yes
CBC Config I/O: Right Dedicated DRL Lamp/Right Signature LED Present...- No
CBC Config I/O: Left Dedicated DRL Lamps/Left Front Turn Signal #2...- No
CBC Config I/O Usage: Front Park/Signature Lamp Left- Pin A 7- YES
2014 CBC Config I/O & Feat: Front Park/Signature Lamp Right - Pin A5- YES
2014 CBC Config I/O & Feat: Headlamp Module LIN Diagnostics Line Enabled- YES
CBC Extern.Light Calibr: Signature Light Present- YES
CBC Extern.Light Calibr: Redundant Front Turn Signal- NO
CBC Extern.Light Calibr: Signature Dropout Enabled- YES
CustSetMenu 1: Adaptive Front Light system CSM Present- YES
P/T Chassis Net: AFLS Discharge Lamps- Enabled
