hoping someone might be able to give some advice on better accessing the light grey and dark grey connectors that are fixed to the PDC just rearward of the battery in the hood/engine compartment,. the connectors where we snap in the wires with metal blades. the two connectors on mine are angled down a ton, so kind of hard to access, see them, etc. looks like the two connectors sit on a molded plastic mount which seems to snap into a receiver on the pdc itself (at least I think that's the pdc with all the fuses for the aux buttons etc). i pushed that tab in and tried wiggling the connector holding assembly up, it seemed to start coming up ,and then hit solid resistance, cant see back there too well...figured before I wrench and really pull on it, I would just ask as maybe there is a simpler way. the one (top) cover of the connector came off but the lower connector I cant figure out how the cover releases and there isn't too much room to wiggle it off...it I couldn't I wouldn't release the two at all. so maybe that's question # 2, the lower of the two connectors... and lastly, I see the bundle of blunt cut/heat shrunk cables as well. i presume when I strip off the wrap at the end, they have colors to match the tails of the connectors in the cabin after in snap in the two harnesses inside under the dash??
more simply stated: how do I release those two connectors so I can access the a bit easier:? how do I get those outer cover off that connector into which I snap the bladed wire and 3) are those bundled wires colorized or notated so I don't have to strip all 4 to setup one pass thru?
tku!
