Fog lights
eljefe
Oct 22, 2021
Hey all. I got a Tradesman which didn’t come with fog lights. What are you all using? Thanks.
Myfast70
May 27, 2021
I'd look into the Baja Designs. My Limited comes with fog lights already but I may end up swapping them for thr BD at some point
KnuckleHead
Dec 10, 2020
Yeah, I swapped out the stocks with the BDs on my PW. I went with the SAE version, and they are a little brighter than stocks. I didnt want to do the regular ones because I like to run them all the time and I dont want to be the a-hole running around blinding everyone. At some point, I might swap them for the regular ones, but i suspect you wouldnt want to run those all the time.
Myfast70
May 27, 2021
Realized I posted in wrong spot.
Added the Baja fog lamp swap before it heads out to Michigan to AEV.
I saw these in another post and if I do switch them out I will go with the yellow color
Wpg_Ram
Jun 5, 2020
2019 Big Horn, didnt have fogs ... went with the factory add ons ... Needed switch, bezzels, fogs, wiring. You can use the AlfaOBD to activate or get the dealership to do it for you. Check under Modifications & Accessories, there is a sticky with all the info / part numbers. Its quite easy to do
CanadianIronhead
Banned for flashing
Nov 27, 2021
Alberta
Ah! You're that guy running around with fog lights on all the time with no fog in sight?!?!
‍I can't stand those people, most of the time I'll blind em with my Baja designs non SAE fogs with a quick blast, or the light bar.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
So, instead of refocusing down to the right (because you already know the brighter lights are coming at you), you’re response is to instantly and unexpectedly blind that person, potentially causing him to lose control and put other drivers in the area in danger?
Yea, that's a huge D* move there partner.
Do you also chase people down that run yellow lights, don't use their turn signal, or speed and give them the what-for as well?
How about the RAM owners whose fog lights come on in a turn or with a signal? You make them "see the light?"
SMH.
CanadianIronhead
Banned for flashing
Nov 27, 2021
Alberta
SMH.
I think you're really taking things out of context here, or maybe you just like to argue who knows.
I don't give people the "what for" as you call it for everything of course not, and I am one of those turn signal fog light guys, but it's insufferable when traveling down these straight and flat highways in my neck of the woods and some dumbazz leaves his highbeams on or very bright fogs for no apparent reason.
Can we all just agree that yes I may be an ass and am very hard headed but people with fogs on all the time are pretty dumb?
