Non-Wiring Related Parts List Round Up / Consolidation I cross-referenced posts to verify part numbers as well checked part numbers against Mopar sites to look for changes.
OEM Halogen
Courtesy of
@b307a1 Post #60
Quantity of parts and price.
2ea) lamp-fog 68202187AA - $102.00ea. (cheaper elsewhere courtesy of
@TogaLock77 Post #65)
1ea) Bracket - Fog lamp 68449383AA. both left and right sides come together. - $22.82 ea.
1ea) Bezel- Fog light 68449341AA. Both left and right sides come together. - $13.68 ea.
6ea) Bolt- 68368951AA. These are to mount the fog light to the bracket. - $0.85 ea.
8ea) Nut- 68404464AA. These are j-nuts that go in the mounting holes in the bumper bracket so you can mount the fog light bracket to it. - $0.50 ea.
8ea) Bolt- Hex Head 6508065AA. These screw into the j- nuts-. $1.39 ea.
Courtesy of
@b307a1 at Post #69 You will also re-use the hardware that you removed from the fog light blanks covers
Courtesy of
@TogaLock77 Post #89
Installing Diode Dynamics LED pods in the Halogen bezels and brackets instead of the OEM Halogens. Also same hardware needed as listed above at Post#96
Another Diode Dynamics Post #234 and Post #244 Courtesy of
@ramblinChet
CJCOffroad has Baja Design complete kits which include bezels, brackets, lights, harness etc. Courtesy of
@herdbull at Post #259 and
@Sage6058 at Post #260
OEM LED
Courtesy of
@pionex_80 at Post 205
@2ea LED Bezel Fog Light 68449321AA
Courtesy of
@vzar47a at Post #290
650806AA (
incomplete part number) bolts to mount Lights to brackets - 4 each side
68368951AA bolts to mount brackets to truck - 4 each side
68404464AA j-nuts, used with bolts above - 4 each side
68449321AA bezel for LEDs (halogen bezels are different), one set comes with both sides
68449381AA brackets for LEDs (halogen brackets are different), one set comes with both sides
68273292AB right LED assembly
68273291AB left LED assembly
68377331AD harness that runs from left to right LED
Regarding LED Bezel Park Assist Holes
NO Park assist holes bezel 68449321AA
WITH Park assist holes bezel 68449338AA
