Fog light for 2019 Tradesman
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
MoparMom
Mar 28, 2022
But you're talented, Rockcrawlerdude. Some of us old geezers just want plug and play. Looks like great work on your part, too, btw.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Plug and play is great!
I’m lazy and cheap.
Mine are wired into my parking lights circuit so they’re automatic with the headlights and stay on with high beams. Fuse and relay protects the trucks factory circuits hopefully.
copcarguy
Jun 13, 2021
I’m lazy and cheap.
I used the cab clearance light fuse as the 12V point to trigger the relay for my fogs…
22BlackBigHorn
Jul 13, 2022
Guess what I am doing tonight? :)
I do have one question. I didn't see where or how people are mounting their Diode Dynamics SST lights.... Do you mount them to the bracket first, and then install the bracket on the truck???
I wanted to get the LED ones but then I just love how the bigger square lights look. I thought about maybe even buying the factory light and throwing a Lasfit switch back in them...
Any pointers would be great on installing the light in the bracket.
Those side nuts are a PITA to get off and on!! WOW! Thankfully they are just a little bit more than finger-tight!
I have the bezel's swapped out and tomorrow I'll figure out which light I want to use.
Linked4door
Aug 26, 2020
Did you buy a kit or just the light pods? If you bought the kit, it will come with their bracket that mounts the pod to the factory bracket. See attached pic. If you bought the ods by them selves you will need to get the brackets.
DD light mounts to their bracket. That assembly then mounts to the factory bracket in your pic. That whole assembly mounts behind the factory bezel that bolts to the bumper. I used a ratchet wrench for one of the bolts on each side I couldn't fit my Milwaukee 1/4 drive ratchet. It's pretty straight forward.
loveracing1988
Feb 16, 2021
Mount the bezel, mount the lights into the adapters and then mount the whole thing into the bumper. If you drill a hole into the factory fog light mount you can get to the side allen bolt on the diode dynamics a lot easier.
22BlackBigHorn
Jul 13, 2022
Did you buy a kit or just the light pods? If you bought the kit, it will come with their bracket that mounts the pod to the factory bracket. See attached pic. If you bought the ods by themselves you will need to get the brackets.
DD light mounts to their bracket. That assembly then mounts to the factory bracket in your pic. That whole assembly mounts behind the factory bezel that bolts to the bumper. I used a ratchet wrench for one of the bolts on each side I couldn't fit my Milwaukee 1/4 drive ratchet. It's pretty straightforward.
I had some Pods from my previous truck that I will use in for the time being. I do want to use the SST Lights down the road. Do you know if you can buy just those brackets separately ? I can't seem to find it.
Linked4door
Aug 26, 2020
They used
They used to sell them for $10 to $20 for just the brackets. I can't find it anymore for some reason. I can only seem to find there kit for about $100
Try giving them a call, there customer service is outstanding. Alternatively, if you look at the bottom of the page there is a HUGE list of vehicles that use the same bracket. You could grab some from a junkyard or used online for cheap and modify them to fit your pods.
You could also call Baja designs and see if you can get the bracket from them,. There mounting point is closer to the bottom of the bracket to fit the bolt pattern of their lights.
el_barto
May 25, 2020
Anyone try out the Diode Dynamics “elite” series fog lamps? Rated lumens/candelas is equivalent/ a bit lower than their SS3 Sports, but still impressive output and a superior cutoff which is less likely to cause glare for other drivers.
vzar47a
Sep 26, 2022
I'm trying to decide between the OEM led lights and something like BD SAE lights. I am starting from scratch, and am looking at something like a $250 difference between OEM and Baja.
Seems like most people who swap out the OEM leds are going for something beyond SAE, and I am sure it's a huge difference. I want to stick with SAE, so for those of you that swapped out the OEM for Baja SAEs, was it a significant difference?
I like the cornering light function that comes with OEM. For those of you who installed non-OEM lights, does the cornering function still work with your lights? Seems like it should, since there is only one power wire going into the OEMs. So if it worked before a swap, it should work after, right?
Linked4door
Aug 26, 2020
I went from the oem led fogs to the Diode dynamics ss3's (pro with sae fog in yellow) and couldn't be happier. You can buy and swap the lens betwen white/amber and sae, como, ect. I had originally ordered the BD lights but issues with my order and poor customer service from the vendor I ordered from I went with the DD lights. Lighting is subjective, but IMO the DD are drastically brighter than oem straight a head.
While my cornering feature still works, them oem do have an advantage here due to having a much wider side angle. So the oem LED is is brighter on the far sides of the road.
22BlackBigHorn
Jul 13, 2022
That looks good Linked4door!
Someone had a set of those factory longer lights for sale in my area. They were $50 and I asked about them, then 4 days later he said they were sold.
I just ordered a set of these to replace my LED Pods. They are spot and they are not ideal for highway usage.
These are at least DOT so hopefully, I can use them without getting flashed all the time.
eljefe
Oct 22, 2021
I purchased a set of OEM fogs, then the appropriate OEM light switch; also purchased the OEM wiring harness. Had to purchase the OBD jumper to bypass the 5th Gen OBD. It was a full day PITA. Be sure to have a second set of hands. But glad I did it.
22BlackBigHorn
Jul 13, 2022
I totally wanted to do this as well. Was it a PITA to get the wire in the pin on the BCM? I hear it's not plug in play but some work.
I am still thinking about going this route!
Have a parts list?
eljefe
Oct 22, 2021
Here is everything you need. Yes, major PITA but worth it I thought.
vzar47a
Sep 26, 2022
Didn't see it earlier in the thread, what size wire do you use for the BCM pins? Data sheet for the pin says it takes 18-20 AWG, but I'm wondering if 16 would work?
