It does, but with these crazy times.... It could be more than a year before we go to court. FCA is fighting it all the way.
Lawrenceburg was the servicing dealership.Your dealer wouldn't happen to be in the Lexington area would they?
I originally purchased it new from Shelbyville.Ahhh... that explains a lot. I live 5 miles from them and won't even step on their lot because of all the horror stories I've heard from friends in the car business. I drive to Shelbyville as my #1 choice, and if for some reason I can't use them I go to one of Bob Allen's dealerships in either Frankfort or Danville. These people in Lburg are crooks. It's a real shame.
Did you ever get your truck fixed? How did it end up?
Heres a little tid bit I learned a while back. When i called cummins about my pump issue they told me they cant touch that engine, they couldn't tell me why but, they did say this: Remember the customer is always right, and that I should bug ram till they do something.While true in a literal sense, I didn't buy a Bosch pickup. Ram/Cummins made the decision to use a component that has a history as a KNOWN PIECE OF CRAP for ten years or more. They get the black eye.
For the 15+ years I have been around the CTD world Chrysler has been providing their own warranty for the engines, leaving Cummins out of the warranty loop, unlike the traditional commercial truck business.Heres a little tid bit I learned a while back. When i called cummins about my pump issue they told me they cant touch that engine, they couldn't tell me why but, they did say this: Remember the customer is always right, and that I should bug ram till they do something.
In 20011 Chrysler filed bankruptcy, so Fiat bought Chrysler, after Chrysler filed bankruptcy, the contract between cummins and Chrysler was null and void, anyways Chrysler aka fiat now, came to cummins with a new contract that stated that they cant touch that engine only ram can. Used to, if u had a issue with a cummins engine you could take it to cummins and they would do the warranty, with that new contract they cant.
I did back in March after I hit 35 days in 4 months of ownership, FCA has denied buyback twice already. My lawyer is not sure what FCA is trying to do here as I'm going on 69 days out of service. If anyone else is pursuing lemon law or MSRP swap you are in for a fight with FCA. My lawyer thinks they are trying to use Covid as their excuse.
The pump should never have been designed with the rail supply and cooling supply one and the same. It needs to be spilt like the CP3 or bypassed like the Ford kits that are available.I wish i could get my hands on a failed pump and spec it out, my guess is the ones that fail have the lifter bore oversized by a thou or 2 that allows it to turn, they could have very easily had a keyed lifter with a broached bore so the lifter could never turn that would be one well designed pump that would last a long time if they really wanted to keep using a roller style lifter...
I understand that... its very similar to the vp44 issues the lubrication and heat cycling causing failures, of course they are very different failures and designs but same cause (heat and lube) seems like every second injection pump they try is junk one step forward one step backThe pump should never have been designed with the rail supply and cooling supply one and the same. It needs to be spilt like the CP3 or bypassed like the Ford kits that are available.
Sorry to hear about that (although not really that surprised). They can't tell you what the issue is until they have fully investigated what the problem is. Once they confirm that it's the CP4 failure they'll order the parts, and depending on back orders, it will likely take about a month or so for those to come in. Once they have the parts it's a quick repair - probably two days or so and then it's done. Eventually you'll get your truck back.I have a 2020 Ram 2500 Cummins 6.7. Fuel pump went out I believe on Friday. Talked to the dealer and I have asked if it the fuel pump that has failed and they told me they can’t confirm at this time as they are waiting on hearing back from Chrysler!! They can’t tell me anything as of yet until they confirm with Chrysler, this is piss poor customer service. I only have 10,500 miles on this truck.
Ford is a turdSorry to hear about that (although not really that surprised). They can't tell you what the issue is until they have fully investigated what the problem is. Once they confirm that it's the CP4 failure they'll order the parts, and depending on back orders, it will likely take about a month or so for those to come in. Once they have the parts it's a quick repair - probably two days or so and then it's done. Eventually you'll get your truck back.
I'm pretty sure I'll be trading in my Ram once the 2022 Ford F250's come out (with hopefully an upgraded interior).
