jeffjcalweb
- Joined
- Apr 4, 2021
Hey - couple things. First, Brewbud, I am in Kalifornia and it was not even an issue at all. This is emissions intact tuning and I'm not deleting anything. When the time comes for smog etc I'll revert to Stock tune to not complicate life for anyone.
Ok that said - I just installed the EZ Lynk and uploaded my first tune. I chose the "V3.2 Jack LTOW wEB" tune. If I'm interpreting their website, I believe this means "40hp/80lbft". I don't know what "w EB" means so I've sent a couple of questions in to the support. There were other tune options, including ones in a menu "Mild Trans Tuning - Stock Feel w/Added Line Pressure". Because I don't know enough, I didn't choose anything from there.... I would like to understand why or why not I'd choose those options compared to the "Standard Shift Schedule w/TCC" tunes. That's part of my questions to support.
The install process was exactly as seen on this video:
Tip: Make your life super easy and just pull the panel off above the brake release. The "gateway" you plug into sits right behind it and you can easily reach it, no tools needed.
The Auto Agent app paired easily and the steps are simple to follow. There is a firmware update that is done when you first connect which will "reboot" the EZ Lynk and you'll need to reconnect from the app but no big deal.
After that it really is as simple as follow the directions and select the tune you want to upload. On my truck that process took roughly 5-7 mins.
So from an "open the box" to "tune installed" I was done in 20 minutes, no tools, every step was easy to follow.
First time starting truck, no issue, no warning lights, no vehicle messages etc.
First drive I can't honestly say much as I'm being realistic - I choose a mild tune and I just drove around the block, more to make sure I could then to test anything
Will report after a bit more of a chance to drive normal conditions this afternoon.
