They’ve never added a feature back to an older model before, so I wouldn’t expect it now.I wonder if they will add it to 2022s that have 360 deg cameras as and update?
Nope!
But you can add the Naviks module which enables the mirror cameras on your 12” display when you hit the turn signals.
Did you do the factory resetI have the same problem with my 2023 Ram 2500 HD rebel. I know the cameras work because I can manually turn them on. However, they do not work with the blinker like they are supposed to and I have it set to on in the settings.
I have not but will this evening and post if it works.Did you do the factory reset
What package did you get that they owe you cameras?I spoke to the dealer about it and reported it here.
Also found out they owe me 4 trailer cameras, as no one told me about that either.
Scroll through and take pictures. That's what I did. Honestly it gave me a chance to go back over all my settings and there were a few I'd forgotten about that I ended up changing.Is there anyway to save any settings before doing the reset? Presets, shortcuts, any of it?
Mine come on every time I use the turn signal.Just got my 2024 3500 limited. Obviously I’m here for this reason. Factory reset did not work dang it. All the things stated above happened, loss of cameras temporarily etc. Do they come on with the signal or do I need to have someone in the blind spot for it to activate? I’m more than sure the stealership won’t have a clue.
