Blinker Cameras
Clayinfl
May 12, 2023
Tampa, Fl
Does not work in my new 23 2500 Laramie. I will try the reset. I guess that means I can reconfigure everything again? Lol
M-Pressive
Jun 22, 2023
First post, just purchased a 2023 2500 Limited and noticed the cameras would not activate when the blinkers were turned on.
Did the reset last night and they work great now!
Appreciate the insight and fix.
Clayinfl
May 12, 2023
Tampa, Fl
I just went out and reset my uconnect and the blinker cam is now working. Thanks for this fix!
Blowenblu
Oct 9, 2021
I wonder if they will add it to 2022s that have 360 deg cameras as and update?
jsalbre
Oct 29, 2019
ID
They’ve never added a feature back to an older model before, so I wouldn’t expect it now.
mountainears
Mar 29, 2022
Nope!
But you can add the Naviks module which enables the mirror cameras on your 12” display when you hit the turn signals.
Nope!
Annoyingly slow as it simulates multiple button presses.
I hate my NAViKS when it randomly enables the mirror cams.
mountainears
Mar 29, 2022
Yea, certainly not fast in bringing them up. I have found them useful occasionally, but do wish it would be faster.
jsexton
Oct 19, 2023
I have the same problem with my 2023 Ram 2500 HD rebel. I know the cameras work because I can manually turn them on. However, they do not work with the blinker like they are supposed to and I have it set to on in the settings.
phatboy64
Sep 20, 2022
Did you do the factory reset
Nov 29, 2021
Is there anyway to save any settings before doing the reset? Presets, shortcuts, any of it?
jsalbre
Oct 29, 2019
ID
Scroll through and take pictures. That's what I did. Honestly it gave me a chance to go back over all my settings and there were a few I'd forgotten about that I ended up changing.
Technically you could go through AlfaOBD and look at the settings under "Customer Programmable Features", but only a handful of settings are listed there, so I don't think it would be worth it.
Mayhem
Dec 15, 2023
Just got my 2024 3500 limited. Obviously I’m here for this reason. Factory reset did not work dang it. All the things stated above happened, loss of cameras temporarily etc. Do they come on with the signal or do I need to have someone in the blind spot for it to activate? I’m more than sure the stealership won’t have a clue.
Clayinfl
May 12, 2023
Tampa, Fl
Mine come on every time I use the turn signal.
