Aftermarket Cat Back exhaust systems ?
Kimo7
HDRams' Official Greeter
Feb 21, 2020
Northern VA
I'm currently considering the Magnaflow @Kimo7 picked up with an aftermarket resonator like this ($70 or so)
Looking at the catback from Magnaflow, it appears it is basically what they did.
I found my best deal on eBay at a company called rvandautopartsstore. They have a “make an offer” button and excellent customer service - Ralph. I have no fiscal interest in the company, just passing along a possible source. Good luck
Gondul
Prince of Pintops
Mar 10, 2019
Thanks for the tip!
Squatch
Mar 21, 2020
Washington
Any of you guys know if these systems work on both the 2500 and 3500. The Borla system only says 14-18 2500.
dablack21
Aug 30, 2020
Are there any dual exhaust kits besides Flowmaster? I would love to have dual tailpipes straight out the back, but Flowmaster seems to be the only kit. I called a muffler shop, and they can build one with any muffler I want, but I have problems getting into a shop with my busy work schedule.
dablack21
Aug 30, 2020
I found another dual exhaust kit from Gibson. But I can't find any audio. Anyone know where I could find a link? Or anyone here with one?
AlexRAM
Nov 3, 2020
Hi, I have Magnaflow installed on mine. You can look into this.
Feb 16, 2020
I can tell you from personal experience, if you remove the muffler, and resonater, it is loud! My son did this on his 18 then had basically a true duel, straight pipe exhaust. Snapping is the best description. Just like a 70s 350 with straight pipes. The worst part was if you tried to light foot it , eco mode kicked in and it got worse. It has mufflers now lol
dablack21
Aug 30, 2020
I just had a local muffler shop install a Magnaflow SI/DO muffler with 4" wide by 22" long tips straight out the back. Sounds amazing, but it does get a little droney in the cab around 1800rpm. Cost me $600
Crusty old shellback
Apr 10, 2021
On my 21 PW, I just cut the ugly resonator off and put a straight pipe in its place with a nice black tip tucked in nice and tight.
Basically did what the factory should have done.
It's a bit louder at idle and when you get on it. Sounds good. Its quiet when cruising and no drone. I like it. Only cost me $100.
As far as CAI that was mentioned, it comes from the factory with a true CAI. :cool:
Lilbxl
Nov 13, 2020
I just installed the Solo Performance MR 400. Nice rumble and not loud while cruising. Very little drone around 58-61 and none at speeds above. It is loud if you get into though but it sounds right to me.
Mnjblymire
May 28, 2021
I'm about to pull the trigger on the Borla Catback for my 2021. Any issues or complaints since install? Any drone?
Gondul
Prince of Pintops
Mar 10, 2019
Nothing I would call 'drone' (MDS on or off)... I've only done some light towing and still not annoying if it were annoying it would have been removed.
Rear hanger was a pain.. dropping the spare and loosening the heat shield helped.
Otherwise I'm happy with it... Truck sounds 'trucky'. Other than that, it weighs 30# less than OEM.. that's all the performance you get it out it!! :D
Mnjblymire
May 28, 2021
Thanks. I would have my local muffler shop do the install.
Do you have any videos of the exhaust either from inside the cab or outside?
Gondul
Prince of Pintops
Mar 10, 2019
I do of both but can't upload video here...
jadmt
Aug 29, 2020
Age
65
Missoula
finally an honest answer :).. I love the posts where guys are claiming faster response and mpg gains....always amazing what the placebo effect has on people..there is something about a nice deep sound tho that makes it feel faster...
