I think it's a design issue. From my testing on my 2019 3500, the high side pressure from the compressor is lower than it should be. I verified it had proper system charge, per the label capacity. I fully reccoved the system, evacuated for 44 minutes and charged it with an added an extra 0.2lbs of refrigerant over label capacity. When I did a performance test after that, the low and high side pressures initially got close to where the should be and the low side went back down. I believe the body computer monitors and control the compressor clutch circuit and it is disengaging the clutch at too low of a pressure. I am also trying to find specs on the expansion valve because it has a different part number than the one on my 2016. I want to replace it with one with a different superheat rating and see if that makes any difference as well.Mine has knobs.
You are way above my expertise...lol.I think it's a design issue. From my testing on my 2019 3500, the high side pressure from the compressor is lower than it should be. I verified it had proper system charge, per the label capacity. I fully reccoved the system, evacuated for 44 minutes and charged it with an added an extra 0.2lbs of refrigerant over label capacity. When I did a performance test after that, the low and high side pressures initially got close to where the should be and the low side went back down. I believe the body computer monitors and control the compressor clutch circuit and it is disengaging the clutch at too low of a pressure. I am also trying to find specs on the expansion valve because it has a different part number than the one on my 2016. I want to replace it with one with a different superheat rating and see if that makes any difference as well.
I have been certified in R-12 and R-143a service and repair for 20 years haha. I've seen a few things and own all the equipment for it haha.You are way above my expertise...lol.
So new issue to go along with subpar AC on hot days...I was driving into work around 7am today. The outside air is in the low 60s. Too cold for the AC to be blowing right at me, I changed the blower to the windshield. The manual temp was set to 62, and the windshield started blowing HOT. I had to revert back to the face vents because it was unbearable. These HVAC issues have completely sucked my enjoyment out of this new truck.
I have 2019 Big Horn Crew cab and noticed the A/C not cooling as I would expect, I basically have to turn it to max to try and keep up even on mid 80s days. I noticed it right away when I received the truck.
My effort for RAM to help the ac pretty much ended today. Been with the dealer almost two weeks. Reached out to RAM executive they were very responsive however was called to pick up the truck today they said the ac was fine to roll down the windows during hot days to let out the heat, dont use max ac and set fan on 4. Drive around a bit then roll up windows. They said they were able to get the cab cold. I tried it truck behaves the same to me. Its cool but not cold like I think it should be. Nothing else I can do will prob trade it in for one of the new f250 coming out and take the loss. Thought you would want to know how my journey ended.Hi- I mistakingly created a similar thread linked here:
A/C issues
Hello All! First post here in the forum. I recently purchased a 19 2500 w/ the Cummins and have been very displeased with the performance of the a/c system. I live in Texas and the a/c just can’t keep up with the heat it seems. I returned the truck to the dealer last week and they said they...hdrams.com
My situation is similar to a lot that are previously mentioned, terrible A/C performance. Dealer evacuated/recharged the System and said it was working to spec. I was unable to notice any discernible difference.
Super bummed about the a/c performance, my 17 1500 hemi would freeze me out of the truck.
Thanks for the info. I am supposed to have a conversation with someone from Ram over the next few days. I went out on a limb getting another Ram after my issues with my 2019 1500. Sorry to hear they couldn't get your issue resolved.My effort for RAM to help the ac pretty much ended today. Been with the dealer almost two weeks. Reached out to RAM executive they were very responsive however was called to pick up the truck today they said the ac was fine to roll down the windows during hot days to let out the heat, dont use max ac and set fan on 4. Drive around a bit then roll up windows. They said they were able to get the cab cold. I tried it truck behaves the same to me. Its cool but not cold like I think it should be. Nothing else I can do will prob trade it in for one of the new f250 coming out and take the loss. Thought you would want to know how my journey ended.
That’s really stinks! I am still hoping Ram will come out with a fix. There is no way they can expect us to pay 70k for a truck with piss poor a/c.
they said the ac was fine to roll down the windows during hot days to let out the heat, dont use max ac and set fan on 4. Drive around a bit then roll up windows. Nothing else I can do will prob trade it in for one of the new f250 coming out and take the loss.
I asked if there had been any trends or other instances of people having this same issue. He said there was not.
@RamCares, lying is not a good look. A sad turn to say the least.
Hopefully it's just one bad employee.... but sadly he was trained to answer that question by someone higher ranking. There are so many documented cases of poor AC performance in the 2019+ Rams, HQ ignorance to it has not been possible for many months.
Well, I can't say whether the particular employee I spoke with was lying or not. It is possible he was unaware, which is why I referenced the forum.
