@RamCares, I performed an A/C Performance test per the service manual using a Mahle ACX1180C R-134A Recovery, Recycle, Recharge machine and the low pressure side was slightly lower than specified(23psi), and the high pressure side was low (175psi) vs the specified expected pressure at the humidity corrected ambient temperature of 80F. The duct outlet temperatures were 2-5 degrees above the expected temperatures.
With those results, for anyone that is certified to work on A/C systems, and the service manual, this indicates; a low refrigerant charge, restricted refrigerant flow to the evaporator, or a faulty compressor.
