Danny_houstonTx
- Joined
- Apr 17, 2020
Thx
Thanks for sharing - I saw this video but I just wished he shared his tsb’s in youtube comments.
I'm not convinced that the Aisin transmission has a sophisticated "learning cycle", but I've learned how it behaves and corrected my driving style accordingly.
For example:
If I come to a full stop (stop sign) and I pause a couple of seconds before accelerating = transmission engages very smooth.
If I come to a stop sign with at a high decelerating rate and I don't make a full stop (rolling stop) then I jump on the throttle = transmission "slams" into gear abruptly. And this condition gets worst when the stop and go is uphill !!
My conclusion: this tranny might be "heavy duty" but it doesn't like to be "manhandled" at all.
At first: I had the same transmission symptoms and opinion as most of you guys. Now that I am predicting its behavior: I have come to really like this tranny.
Wait 'til you get in town traffic when pulling heavy, where you have to be on and off the throttle to work through lights or oncoming cars, and the Aisin get confused and makes the whole truck shudder. It's a real pip. The Aisin is so stout, but why Ram can't get the thing dialed in is just baffling to me.I experienced the slam shift for the first time yesterday.
Barely a rolling stop, which I've seen posted elsewhere as a contributing factor, and it banged so hard I thought the trans dropped on the road.
325 miles on the truck.
I picked it up 3-10-20 so I don't know what code is installed. It is going into the dealer Monday for some other issues. If they update it, I'll make sure they document before/after levels on the work order.
Some of them work - some of them don't. Mine is ok but I've learned to operate around the tranny's idiosyncrasies. It can be quirky.I have towed in heavy traffic, pulled up 6 and 7 grade hills [mountains] with my Asian with 14000 # behind it and have never experienced anything close to being wrong, it just keeps pulling , even while coming down 6 or 7 grades transmission and engine brake work perfect together. Just cant figure out why others are having some type of issue with the Asian.
Just talked to the dealer. They are going to install the flash update. Still not sure if they would have applied had I not asked.Question, I just purchased a new 2019 off the lot. They are delivering to me today from the lot due to Covid restrictions. Prior to delivery they were going to apply the windshield wiper recall. Would they also apply the TSB transmission updates prior to delivery or would this normally be a special request.
I would have thought that they would update everything before selling/delivering.
Sent from my ONEPLUS A6013 using Tapatalk
Hello, I have a 2019 Ram 5500 / Aisin - with the same issues of tranny downshifting way too aggressive only while I’m tow haul mode - too it to the dealer and had ecm and pcm udadated - nu luck - same issues... truck has 52k miles - this is really frustrating.. Ram Cares - can you please confirm that there is an issue with this problem and if so - could you please provide the exact software version so I could present it to my dealer in Houston ?! Thanks
attached is what was done to my truck today - issue has not been resolved...
Hi @Danny_houstonTx - Would you mind following up with me via private message? I would like to escalate your situation to a Case Manager which will provide the dealership and yourself with an individual who will review your concern, then assist you and the dealership in exhausting all available resources to have the concern addressed and resolved.
Mark
RamCares
Private message send ! Thanks
Trans learn mode: check. Everyone should be asking the dealer for the quick learn after a flash. Admittedly I don't know if this is applicable to the Aisin.
Thx - was this for ram 5500 ?Quick learn seems to be applicable to the Aisin because here is the service for one of my visits to the dealership. NOTE: The service log says TSB 21-001-21, but that is a typo. It should be TSB 21-001-20.
Got it - thanksNo, mine is a 2019 3500 HO/Aisin.
