OLEJOE
Has anyone ever stripped out 1 of the air filter box lid screws and if so how did you fix it ?
I don't remember how they are threaded. Is it a nutsert from the bottom? I've fixed a couple on other trucks with JB Weld to hold the threaded piece in. On another if I recall correctly, I used a JB Weld or similar product and tapped it after hardeningHas anyone ever stripped out 1 of the air filter box lid screws and if so how did you fix it ?
It’s a self tapping screw in plastic. All of the other screws tighten down to a stop but 1 just doesn’t get tight like the other ones.I don't remember how they are threaded. Is it a nutsert from the bottom? I've fixed a couple on other trucks with JB Weld to hold the threaded piece in. On another if I recall correctly, I used a JB Weld or similar product and tapped it after hardening
Can you run a zip tie through one side of the hole? Will give the screw more to bite on temporarily till you come up with something else. I don’t remember exactly what it looks like and I’m not by my truck.It’s a self tapping screw in plastic. All of the other screws tighten down to a stop but 1 just doesn’t get tight like the other ones.
That’s what I did. I cut just the end off of the zip tie and and had to fold it lengthwise with a pair of pliers, then shoved it down in the hole and it got really tight. I learned a trick to putting the screws back in. Turn them counter clockwise until you feel them drop down then tighten.Can you run a zip tie through one side of the hole? Will give the screw more to bite on temporarily till you come up with something else. I don’t remember exactly what it looks like and I’m not by my truck.
I use the Fleetguard AF-27684 its the only filter I use, I can buy it cheaper than Mopar brand filterIs this still an issue? I just grabbed an AB filter from my dealer (Red Deer, Alberta). Was $60CAD IIRC.
Parts desk said they used the glue strip version for a short time. They were finding the strips had dried out and were laying in the bottom of the airbox when the trucks came in next time. They switched back to the AB version when supply came back.
Either the Mopar 53034051AB or Fleetguard AF27684 is fine. Both are the same filter and are 100% the filter these trucks should have.Is this still an issue? I just grabbed an AB filter from my dealer (Red Deer, Alberta). Was $60CAD IIRC.
Use hand tools instead of a battery operated drill and that won’t happen.I don't remember how they are threaded. Is it a nutsert from the bottom? I've fixed a couple on other trucks with JB Weld to hold the threaded piece in. On another if I recall correctly, I used a JB Weld or similar product and tapped it after hardening
Hmm, interesting theory. I’ve started having soot based regens about everyday, the past week. Right after a LOF, same fleetguard air filter I’ve been using. IDK, I’m at 55k and emissions warranty is kaput. I’m going to be putting a new exhaust on.Has anyone installed a filter minder on one of these trucks? I have been trying to find someone who has and keep coming up with nothing. I have heard that it’s not needed but Im wondering if the filter housing is causing some kind of restriction making the particular filter(s) the only ones that will work. I found some old threads about the 03’s having the same issues and many modified the air box to correct it.
I’m anxious to hear the details.Hmm, interesting theory. I’ve started having soot based regens about everyday, the past week. Right after a LOF, same fleetguard air filter I’ve been using. IDK, I’m at 55k and emissions warranty is kaput. I’m going to be putting a new exhaust on.
Lube Oil Filter, lol. From my quick lube days many moons ago.I’m anxious to hear the details.
LOF?
Did you lube the seat and steering wheel? LolLube Oil Filter, lol. From my quick lube days many moons ago.
You might try a couple of stationary regens back to back and see if that helps. This is from my personal experience:Hmm, interesting theory. I’ve started having soot based regens about everyday, the past week. Right after a LOF, same fleetguard air filter I’ve been using. IDK, I’m at 55k and emissions warranty is kaput. I’m going to be putting a new exhaust on.
