riverside jeep
- Joined
- Jan 31, 2021
I did my power side steps ( they are a pain if you working on the truck and they deploy constantly), and my 2 wheel drive low range. Soon an air compressor.
Explain that to me because I wish there was a function or button to keep the running boards deployed at least when parked as you have just stated.I did my power side steps ( they are a pain if you working on the truck and they deploy constantly), and my 2 wheel drive low range. Soon an air compressor.
I don't believe that function could be controlled though the switch. Someone smarter than I may be able to steer you in the right direction.Explain that to me because I wish there was a function or button to keep the running boards deployed at least when parked as you have just stated.
Once I get a dump trailer I may try to rig up one for non-latching and make a harness that plugs into a hacked version of the hydraulic remote cable. Be nice to raise the dump from inside the truck for spreading.
I thought you could go into settings and change to take if off of auto deploy, then when you manually deploy them they'll stay down even with the door closed, until you either manually retract them or exceed 5mph.Explain that to me because I wish there was a function or button to keep the running boards deployed at least when parked as you have just stated.
Please keep us (me) in the loop on these, especially how you wire up #4. I want to exploit my dual 440 amps with probably the Renogy DC-DC charger for the trailer, and your plans on the high power rely would be wonderful to review.I have yet to fill them in.
1 - Front light bar (not purchased)
2 - Ground lights (not installed)
3 - Rear service lights (not installed)
4 - High power relay
5 - Auto level air suspension (not factory equipped of course)
6 - Air compressor
4 is to power the fifth wheel with the dual alternators so I can run the AC in the RV, and/rapid charge the batteries. It also lets me boost a car from the rear bumper if needed. (With a different plug in cable to the bed with clips. The usual one I use is from the connector in the bed and hard wired to the RV battery bank.)
2/3 are to see when I arrive at a campsite after dark. So they purely light up the ground around the truck and trailer.
Revjvegas is correct, I think.....I thought you could go into settings and change to take if off of auto deploy, then when you manually deploy them they'll stay down even with the door closed, until you either manually retract them or exceed 5mph.
I'll have to test that theory next time I'm out by the truck.
Amazon 20$ you can buy a wireless winch kit it works just beautiful for spreading i have one on my trailer mainly for lowering the multi stage cyl in winter (can take 10 mins on a -40 day) so i can be warm in the truck while it goes down lolOnce I get a dump trailer I may try to rig up one for non-latching and make a harness that plugs into a hacked version of the hydraulic remote cable. Be nice to raise the dump from inside the truck for spreading.
What no banana peels or turtle shells??!!1- Machine guns
2- Smoke screen
3- Oil slick
4- Surface to air missiles
I too had no idea this existed. Besides learning my truck order has a build sheet as of today this is the second best thing I have learned today.2WD LOW box and under hood LED.
Coming: reverse lights on truck, trailer, including reverse trigger enable/disable switch.
