Well it's been awfully quite out there for the last 2 days, hopefully everyone has been enjoying the weather and there new rigs. I finally got my bak flip mx4 on Thursday. Minimal wear from 90% perfect shipping. I talked to bak about the small rub from lack of foam protection and I love the product and im happy with it and i don't want to return it , so could they get me a touch up paint stick. She was super grateful that i was accommodating and will get me a touch up pen. Took me about 2 hrs to install because the wife kept trying to tell me how to do it. Super easy instal, looks bak flipping amazing ( pun intended), definitely add to the classy look I'm going for.
Did run into 1 problem. As you all know I ordered a Lund toolbox covered in rhino lining. I expressed on how close of a fit it was going to be in clearing the top bakflip panels by 1/4". So that wasnt the problem, it would of cleared as there is no drop down cross piece inside between 8" panel & 24" panel. The problem I ran into is the prop rods that are mounted on side rails ( wich I know that I could remove if I wanted) and the plastic lock pieces for the rods make the 61" long tool box not have enough room. Who would of thought that it wouldn't be the height clearance and it would be the length, not me. I really don't want to remove the plastic rod lock piece on bottom of panels as there pop riveted in and if I take that off then ill be sol on my 5yr warranty. so as y'all know, the other day the 61" tool box came in damaged ( guess it was meant to be) and they reordered it for me. So i have now canceled that order and ordered a 56.75" Lund tool box ( my clearance between BAK prop rod assemblys is 57", so the new box will just make the across bed length. Its the same 20.5" wide and 1" shorter to 18" so that will actually give me now about an inch between box and bak flip panels, so I won't have to worry about that. The new box is still black but not rhino lined. It's about $240 cheaper than the previous and at some point down the rd ill take the new box somewhere like line-x and have them cover it. So the price will probably end up being close to the same after i have it lined. I'm going to post pics
