Looks good those don't look like 37s on 20s.37x12.50 on 20x9 trail ready HD20’s.
12.50’s were a miscommunication, will he found 13.50 next set of tires.
Can you measure the total height of the truck ground to shark fin
Yes, I’ll have to measure overall height tomorrow.Looks good those don't look like 37s on 20s.
I like them to was thinking of doing 35s . If you do 37 or find any pics with stockers with 35 or 37 like your talking about post themAm I the only one who absolutely loves the stock night edition wheels. Robust, great finish, easy to clean. I'm gonna keep them, space them out 1.5 inches and put 37s on them.
You don’t have to, it just may bother you when you see your driver side tire sticking out a little further than your passenger side. I noticed no difference in steering or handling before and after adding it. I waited several months before I did it.so to add a 2 inch leveling kit..spacer like the zone for instance..i also will have to get the adj trac bar? to recenter the axle in the truck...
Are u on factory airride?? What's the height of the garage u park in 7' or 8'
No air ride. Stock rear(for now), garage is about 7'10 at the door. We lucked out with that. When I order the Thuren track bar I'll also get his rear +1 inch springs. 1 inch of rake on a big truck looks proper. Sits dead level right now.Are u on factory airride?? What's the height of the garage u park in 7' or 8'
I LOVE that Red.
Did you end up going with wheel spacers as well?No air ride. Stock rear(for now), garage is about 7'10 at the door. We lucked out with that. When I order the Thuren track bar I'll also get his rear +1 inch springs. 1 inch of rake on a big truck looks proper. Sits dead level right now.
Nope. Those aren't stock wheels. 18mm offset 20x9 Dirty life 9300's.Did you end up going with wheel spacers as well?
Doesn't need a lift...just a levelbunch of great looking trucks here.
Am I the only guy that thinks my truck doesn’t need to be lifted
I purchased a 2” BDS / FOX 2.0 kit in anticipation of needing the level.Doesn't need a lift...just a level
That's not very much at all. Mine was box stock and had almost 2.75 inches of rake. Now it is dead level.I purchased a 2” BDS / FOX 2.0 kit in anticipation of needing the level.
But, even with the AEV bumper/ Warn winch, the front is only 1.75” lower than the rear.
So, I installed the shocks and left the level kit in the box.
