What are people using for leveling/lift kits?
BUzzard
Nov 19, 2019
get the rough country bar. easiest adjustment.
That’s probably the one I will go for. I haven’t heard anything bad about it. Do you know the factory torque specs on the bolts? The instructions (on the website at least) say to torque to factory specs, and I can’t seem to find those when I do a search......
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
i thought it was something crazy, 150ftlbs or something. i just made sure it was super tight. i've checked it a few
times and it's solid.
Cummins3
Nov 23, 2019
Those of you that have installed a lift if possible can we get a overall height measurement. Ground to sharkfin? And your setup: what lift, tires, wheel, combo, air ride or not
RamGuy84
May 17, 2019
So I had originally ordered the Carli leveling kit. The shop that I used was able to get me the 3.25” kit instead or order it I should say. I have the appointment for May 6th pending I get my rims and tires by then. Yes I’m keeping my Ram, no Ford! I can’t break tradition!
Verado300
Aug 23, 2019
BDS now has their 4" lift kits out for the 2019-20 Ram 3500 swd. They have adjustable track bars for an additional cost. I talked to them this week on the availability on their 6" kits, and he told me hopefully by mid summer.
RamGuy84
May 17, 2019
I did look into this, but I just trust Carli more and assume a better ride.
Cummins3
Nov 23, 2019
Park.. is your air ride or coil rear.... Do u have better pics truck looks good what's the total/max height of ur truck
Parkerlouis13
Apr 28, 2020
I have coil rear. My measurements were around 43 inches to the middle of the fender lip when I had the stock wheels. I don't have many pics of my truck but I did take this one during the day after driving around Baja Mexico in the rain.20200310_083557.jpg
Cummins3
Nov 23, 2019
Sharp....What's the height from ground to tip of sharkfin.
Verado300
Aug 23, 2019
I did an ICON 4 1/2" lift for my factory air ride Limited. Fuel Sledge 20" +20 offset with 37x 12 Ridge Grapplers. I did the Stage 4 Kit with front and rear track bars. No cutting/ trimming - very slight rubs at fuel lock due to Grappler sidelugs. Used Hypertech tuner to reset tire size. No Codes or issues. Factory air ride funtions as normal. Rides much better than stock. I got tired of waiting on the other guys: lifts for factory air ride must be the last on their lists.View attachment 3388View attachment 3389View attachment 3390View attachment 3391View attachment 3392
What are you doing for a spare tire? I have heard it is not good for the rear axle to use a smaller, like the OEM, tire. On my 3500, there is no way a 37 tire would fit under the bed, so I would just have to keep it in the bed. If I kept it at home and needed it, there is no way my wife could pick it up and put it in her vehicle. Or, just take a chance and not worry about having a flat. Over the last 20 years or more, I have never had a flat on any of my trucks that have had the E rated tires/10 ply.
Vorlac
Jun 9, 2019
I'm just chancing it for now. I carried a 37" spare around mounted to the bed floor with a Fabtech mount in several of my trucks and never had to use them. Just winging it for now, but I might do it again.
Squatch
Mar 21, 2020
Washington
One warning, I was looking at the BDS adjustable track bar, I think I had found it on amazon and there were several pictures of bars where the eyelets broke off leading to complete loss of the track bar which could be a deadly situation. I went with the rough country on my 3500 and I really like it.
RPS1030
Mar 29, 2020
SW UT
I ran 37s on my 16 PW. Obviously wasn’t fitting underneath. So I got a 285/75/17 (~34”) on the steel wheel for underneath all the time. Then strapped a matching wheel/37 in the bed when off-roading or trips.
Plan would be to put the small one on the front (RF preferred) to get home if needed.
Definitely a pain taking up all that room and a big reason why I’m really trying to keep the new diesel smaller.
