Tune for 2022 HD
waveslayer
Feb 26, 2022
There wont be any that can do it without an ECM swap or bench flash due to the nature of the bootloader on the 22s
This is what Banks is trying to avoid... and would be the reason for the long delay in releasing their tuner
MtnRider
Feb 5, 2020
Georgia
They haven't released the tuner for the fourth gens yet and it's easy to crack, it's been coming soon for Years and Years. .... I wouldn't hold your breath Lol His "tuners" are just add on boost and timing foolers anyway.
Riddick
Aug 12, 2021
Yorktown, VA
Negative, the Derringer from Banks does not reflash your PCM. It's a piggy back controller that manipulates what the PCM sees, basically tricking the truck. No different than the Edge tuner and Stealth modules.
Wholeo
May 12, 2022
Maybe a dumb question, is this setup for emission intact trucks?
swordfish
Jun 12, 2023
Looking forward to seeing the first impression from Calibrated Power tuning. I wonder if I have to use their bypass cable if I already have the Kaodtech cable?
Riddick
Aug 12, 2021
Yorktown, VA
From a performance perspective it will be identical to the 19-21s. The interface will be slightly different since the 22-23s will use HP tuners. You will be able to switch between tunes using your steering wheel controls vs a physical switch. I am ready to order but I have to make sure I have a job after July 1st before purchasing :).
I also have the Kaodtech cable and do not see it being an issue.
Riddick
Aug 12, 2021
Yorktown, VA
I ordered the 22' tuning package from Calibrated Power, they are currently on back order. The person I spoke with mentioned they should have more PCMs in a couple of weeks.
I am not sure when I will be installing it since we are moving in a couple of weeks but I will be sure to post up a review and how the install was.
I asked about the Kaodtech bypass cable and they stated any bypass cable will work.
Yes the Kaodtech works i use it with my tuner.
Riddick
Aug 12, 2021
Yorktown, VA
She's ready, only crappy thing is I broke my collarbone 2 weeks ago. Gonna be a bit before I can swap the PCM
Riddick
Aug 12, 2021
Yorktown, VA
Hot damn 4.3k?!
New ecm life is expensive :(
It is indeed absolutely expensive.
6 weeks ago it was 3200, 4 weeks ago it was 3700, now its 4200. Demand is high for new Cummins PCMs. I posted the part number above so others can order them. I paid a touch more going through CP but will make things easier for me in the long run.
Dbowit
Jun 26, 2023
Oh didn’t know it jumped! I mean 3,200 looks prettier. Just wild. I thought my 2018 mm3 set from double r was expensive at the time but we reach new levels here. Seems like the way of the future though I imagine.
Definitely not a lot out there with that part number that’s not china.com
Found the below
1.8k so can save you 800 bucks or so from CP but then you need to ship it to them to unlock which I imagine they would charge 500+ for? I
so probably minimal savings after?
Riddick
Aug 12, 2021
Yorktown, VA
No idea what they charge to bench flash the new PCM but it does need to be bench flashed prior to loading a tune on it.
Found the below
Most companies are ~250$CAD ish for bench flashing/ ecm recovery that i have seen
Dbowit
Jun 26, 2023
I’ll shoot them a email and see what they say and report back. Had a lot better luck finding the ecm’s when you merge all those numbers on the box together instead of spaced. It looks like summit has our cheapest price at the moment.
Riddick
Aug 12, 2021
Yorktown, VA
Good find, make sure you account for the 250 core charge if you wish to keep stock PCM. Looks like they are also drop shipping straight from vendor with an estimated 1 moth lead time.
