The rf hub is located on the back wall towards the driver side about middle of seat back height. The remote start antenna is internal to the hub. You can’t read live data of the hub with AlfaOBD, but you can read the system status of the hub to see the last fob button released and it’s signal strength when it was released. You could shut yourself into the truck, remote start the truck, then press the unlock button once (whether it unlocks or not). Connect to the rf hub and read the system status. Scroll down to RKE Key Fob Data. If it says Last RKE Fobik Button Released: Lock + Panic (lock+panick= unlock for some reason), then you at least know that the rf hub received the signal from fob, but didn’t do anything with the command. If it says Last RKE (Remote Keyless Entry) Fobik Button Released: Remote Start, then you know the hub never even acknowledged the unlock signal from the fob.So i did a bit more of my own testing yesterday and found that when remote start is active or even when the truck is left running and you get out and lock it to say run into a store, the fob is slow to respond in both locking and unlocking events. I am a Radio tech by trade, so I also tested the keyfobs, they seem to be in the 433-434Mhz range, and then also used an Anritsu Spectrum analyzer to see if there was any RFI (RF Interference) being generated while the truck was running. As far as I could see with olacing the unit in the cab, and walking around outside, there was none. I am going to try running the antenna for the analyzer along the wiring that goes to the rf hub and at the rf hub to see if it may be interference coming uo the wiring. At this point I am trying to figure out if the rf hub is properly processing the lock/unlock commands, and just not getting them to the bcm, or if the fob’s rf is somehow being distorted /interfered with causing the rf hub to ignore them. Does anyone know if you can see the live fob press activity info in Alfa OBD? Also. Where is the RF hub located in a 2020 Mega cab?
Yes. Once connected, select the battery icon in the lower right (Android version), then read system status. Make sure you press the unlock button before you connect to the rf hubSo to do that in alfaobd I choose "radio frequency hub(hub) and then "radio frequency hub my13-20 power net"
One screenshot when I pressed unlock button and it didn't unlock. Second screenshot I took when it finally unlocked
Yeah, but not sure what to make of it yet. The hub seems to not know what button you pressed. You would think if it didn’t receive anything at all from the fob, it should say remote start as the last button released. How about three tests in a row:Is that what you were looking for?
Hmmm. I’m curious what a factory equipped remote start reads that has this issue. @Nucknfutz , if you have AlfaOBD, does your last button release after remote starting show not defined?If I read the system after I press remote start only it reads "not defined" same if I press remote start car starts and then press unlock and it won't unlock. Says "not-defined". If it finally unlocks it says "unlock"
I'm not sure if you are home or not. If not I will test after work. But what I want to do next is to place one FOB inside the car and remote start it with another and see if I will be able to unlock from outside.kristof, yes I am using a laptop with Windows 7, and am using a usb to obd cable, the obdlink ex. Also I can not use the door lock button on my door to lock the truck if it is running and I get out either. Pretty sure thats to prevent a person from locking their keys inside but i may be wrong
Correct, that’s part of the keyless go system (fobik safe). The door lock switch is disabled while the truck is running.kristof, yes I am using a laptop with Windows 7, and am using a usb to obd cable, the obdlink ex. Also I can not use the door lock button on my door to lock the truck if it is running and I get out either. Pretty sure thats to prevent a person from locking their keys inside but i may be wrong
Not necessary in gear. It might be that the car thinks you start it (with push button) and the fob "left" the vehicle. Same as if I start the car and get out of it and not able to lock it with fob.Correct, that’s part of the keyless go system (fobik safe). The door lock switch is disabled while the truck is running.
Definitely sounds like the hub is glitching out thinking the truck is in gear or something. Not sure how it can be corrected except a reset or replacement. Thing is, I don’t think there is a hub reset procedure provided for these new hubs on the 2019+ rams like there was on a 4th gen.
Could be, but it would also trigger the fob has left the vehicle message. Either way, I there’s no “serviceable way” to correct why it’s behaving like that.Not necessary in gear. It might be that the car thinks you start it (with push button) and the fob "left" the vehicle. Same as if I start the car and get out of it and not able to lock it with fob.
That's not good. I spoke to Mopar and they told me even if Mopar remote start was installed by me I have to pay $150 for diagnostic fee. There must be something in the alfaobd that need to be set for it work correctly.Could be. Either way, I there’s no “serviceable way” to correct why it’s behaving like that.
