Transmission Issues - Chrysler Denied Warranty - Help!
Kbritt0309
Sep 20, 2023
I purchased a 2022 2500 diesel for my business, new from the plant. The truck only has 14k miles on it right now. Within the first few months there was a transmission issue, we took it to local dealership, and it was fixed under warranty (after many, many months due to the nationwide part list shortages). Once we got it back, again, within a few months we were having transmission issues. Took it to same dealership and they said that it was throwing a code that said the truck transmission had been "overused" due to towing a load too heavy for the vehicle. I know that we definitely did not ever have the truck/trailer overweight/overcapacity. The dealership then told us we need a new transmission for $15k because Chrysler denied the warranty claim. The dealership was no help. I did call the Chrysler customer advocacy line and was told to take it to a second dealership in the next town over. When I took the truck there the second dealership said there was nothing they could do as the truck was now basically black-listed for the denial and turned us away without looking at it.
I see all over the internet many issues with that transmission, in that year/model so we aren't the only ones. I can't find an attorney who will help with a denied warranty claim that is knowledgeable as we are not a direct consumer, it was a B2B transaction.
Can anyone help point me in the right direction or what to do before we lose $15k replacing something that Chrysler should be covering under warranty?
Have you called ram cares? They will bring it above the dealershits head. Also try a smaller dealer they are usually better to work with
Does the GVWR of any trailer hooked to the truck exceed the towing capacity? Does the pin weight of any exceed the stated RAWR? or payload?
mbarber84
Sep 10, 2021
Washington County, PA
I would ask to see a printed report from a scan of your truck with the specific code / data that says the truck was “overused” and “towed a load too heavy for the vehicle”. I’ve seen a lot of diagnostics and codes, never heard of one that can tag the truck for “overusing” it.
The only thing I can possibly imagine is an air ride truck that throws an overload code.
phatboy64
Sep 20, 2022
I agree with this being BS. That said if the BetterWeight Payload scale can determine trailer weight and payload I would assume that data is there somewhere for the dealer to access.
44Dan44
Nov 27, 2022
Maryland
Interested to see how this develops. Interesting point by @phatboy64
From an earlier discussion about built-in trailer weight technology:
jebruns
Feb 28, 2022
Given this statement, can we assume we are talking about the Aisin tranny with the HO motor? I've read of very, very few issues with the 68RFE tranny that comes with the SO Cummins.
At any rate, I agree with others. I'd want to see some documentation on this mystery code.
44Dan44
Nov 27, 2022
Maryland
If you haven't already, check out Matt Barber, he's been compiling data on Regen, Snap Ring Failure, Wrong Air filters etc.
MtnRider
Feb 5, 2020
Georgia
He has a 2500, so it's a 68. All the issues he read on the 68 are self-inflicted from people tuning them and running up the HP (with bad driving habits).
jebruns
Feb 28, 2022
Yeah, I missed that, thanks. So it makes even less sense. Stock trucks running the 68RFE rarely have tranny issues. I'd be interested to see where he's finding the info saying otherwise.
mbarber84
Sep 10, 2021
I’m not sure I’d make that big of a stretch.
The 68 isn’t known for its reliability in stock format. Do they survive under reasonable operating conditions?….yes. But they’ve also historically demonstrated a number of their own inherent design flaws and failures that aren’t necessarily dependent upon bigger wheels and tires, and crappy tuning. They have their fair share of malfunctions and flaws in stock format, with a fully stock truck and responsible driving.
mbarber84
Sep 10, 2021
Thats old folk lore from the late 3rd gen years or the guys throwing much larger tires on the 4th gens with 3.42 gears and abusing the trans not really the 19+ versions The 68rfe is a decent trans and with a simple line pressure change (and gasket change on the early 68rfe) can hold 550HP continuously.
People also say the same for the 48RE i had on my 05 and really i had great luck even running the banks tuner and 35s and pulling 14-15k regularly, i got 200k miles on the stock trans and all i needed was an accumulator seal but opted to change the trans internals completely while i had it apart.
Thompsre08
Aug 4, 2021
Washington State
My truck ('22 2500 Mega Cab Cummins) has been at the dealer for two weeks now with a coded transmission issue. They are supposed to be breaking the tranny down today to get a look at the internals and see if a snap ring failed. My truck has 35,944 miles on it a not abused. I don't like being the outlier but im dead in the water for the time being...
jebruns
Feb 28, 2022
Looks like you do have bigger tires on it? But as you say, there are always outliers, no matter the tranny. I read of very few issues with the 68rfe in 5th gen trucks on the forums.
You put a lot of miles on! My 22 2500 Mega Cummins only has 7K on it, so I'm at the opposite side of that scale.
Would be nice to get more info from the OP though.
