Dan Carey
- Joined
- Nov 8, 2021
so I bought the bypass cable however the instructions say to connect the black and green white into 1 CAN block and white and green or all white into 2 CAN but the harness I have has blue/yellow lead and a pink/green lead. Do you know what leads to to which CAN block ?Did you have the link to the instructions on how to install the KAOdTECH bypass cable ?
Take a good look at the way the plugs lock into the block. There is a small tab on the side that can be cut off if you want to remove the by pass easily.The one with the Black connector goes to the front block, that would the one closest to the fire wall. The White connector goes to the Block that is the double block closest to the light switch. The white connector has yellow and blue wires.
Do you mean to cut these off ?The instructions suck as bad as their customer service who doesn’t respond to emails.
Anyways- use a razor to cut the tabs off it makes life much easier
Thank you for this tip I will be sure to do so.I circled it in blue. It looks like a little shark fin from the side. Lay a razor flat and trim it off.
Man so I was able to solder the buttons on a program the truck. The trunk release works really good but when I press the button for the auto start it just beeps once and thats it.What model do you have? I haven’t seen a Ram with a trunk…lol
I drove for 3 hours and it didnt work I bought some micro buttons off ebay.how easy was it to disassemble the key fob? And what switch buttons did you use?
Here are the buttonshow easy was it to disassemble the key fob? And what switch buttons did you use?
