Here we go!
I wanted to address the longstanding issue of it being almost impossible to put lights in a good location on the Power Wagons. I also wanted to offer serious protection to the intercooler on the diesels. This is the new Intercooler/Winch skid plate for the HD's. It is a true armor package, completely mounted to frame members with M12 bolts with no reliance on the ultra thin sheet metal of the bumper. I'm thinking of offering it in two versions, annotated below: a silver, bare aluminum & stainless model that pairs awesome with the chrome front ends, and a powder coated black aluminum/carbon steel model that matches the black front ends. It's formed from 1/4" aluminum plate for the main center section with steel bracketry inside allowing some adjustment to open/close the gap near the center of the bumper. This is set all the way down (largest gap) in the pics.
It can be run simple as the main center section with an aluminum filler plate (with venting for improved airflow on the diesels), or it can have a protective stainless steel cradle with a 20" Baja Designs S8 light bar in the center with built in adjustability from the front and an anti-theft feature (you can adjust it from the front but have to remove the entire cradle to fully remove the bolts from the light bar).
On the sides we have armored brackets that mount & protect a pair of Baja Designs Squadrons (stainless if bare, steel if powder coated), which bolt to the frame bracketry and flanges of the main plate.
Adding onto the sides are a pair of stainless brackets pointing a pair of Baja Designs Rock Lights at what I think is the ideal spot for navigation and close-in lighting; just high enough that other cars on the road cannot see the light itself as a safety feature!
On the front of the main plate is a port for a NOCO plug. This can be blocked off with a stainless filler plate if not in use. The NOCO plug can be either run as a single or double extension that allows you to keep your block heater, battery tender, or both, always plugged in internally, and gives a really easy external port to plug an extension cord into when you're parked. It's weatherproof when closed up and not in use. No more reaching under the bumper to get your block heater; no more dangling block heater cords during winter; and no more popped hoods for battery tenders!
Let me know what you guys think!
Marcus
Marcus
