Lumpskie
- Joined
- Nov 11, 2021
If I get some time, I'll climb the same rock with the passenger side tire. My prediction is that this additional bushing in the articulink will deflect in the opposite direction:I'd be curious if the right side also articulated as good as the left, or if there is some difference between the two.
I completely hear what you're saying on the rock crawler vs balanced rig, always a trick to keep is in that sweet spot. I think that if you don't mind adding bags to supplement then softer, extended travel springs are well it. That said, I don't believe that most aftermarket spring options work with AEVs spacer style lift. That means you're gonna be changing out an entire lift kit for a suspension swap. I don't know how "worth it" that would be. I should take mine up a ramp and compare to give you some numbers.
Yeah, you should post your setup and your rough numbers. It would be good to see what stiff stock springs and no swaybar do compared to softer aftermarket springs and a swaybar. What setup are you running?
