I’m a huge fan of Michelin’s. I’m amazed at how much they transformed the ride and handling characteristics of every vehicle I’ve put them on. I replaced the OEM tires on my previous truck, 2017 Limited 2500 with the Cummins, with stock size Michelin LTX M/S2’s, they hadn’t merged the defender line into them at that time. I was really disappointed that at 26k miles the Transforce’s were down to the wear bars. I drive normal, and carry out maintenance with attention to detail including rotating the tires frequently. The Michelins had about 14k on them when I traded and showed no wear. The only negative is my MPG dropped a little but totally worth the trade off made up in handling.
I’ve been looking into different size tires when the time comes to replace the Firestone’s on my new truck. My concern is getting too big and rubbing the inner fenders, getting too far off the engineering specs. I really like looking at the lifted trucks with big tires, it’s just not for me. I went through a lot to get the ball mount height and weight distribution adjusted just right on my current tow set up. I’m good with the factory tire specs for my tow needs but I also believe a stiffer sidewall is always better.
It sounds quirky but I like the look of an OWL tire but that limits the size range. I’m 99% there with Michelins (BSW) but open to Bridgestone Dueler LTH too. I don’t need a true mud/snow tire in Northern VA so a HT is more suited to my towing on asphalt. Good luck with your decision. Post some pics of what you end up going with. I’m interested in seeing how much that size tire will fill up the wheel wells.
