Can you snap a picture of the back of your factory wheels? I'd like to see the mounting surface without having to remove one of mine right now.Got my 35X12.5X18 Nitto Ridge Grapplers and Method 305 NV wheels with a +18 offset on today much better for me
Here is mine, Toyo's 37's on AEV wheelsWanting to see some Wagons 18+ preferably with 35’s and 37’s on stock or levelled suspension.
DoneCan you snap a picture of the back of your factory wheels? I'd like to see the mounting surface without having to remove one of mine right now.
Perfect, thanks! I was hoping the pockets between the studs would be a little deeper.Done
Jesus those are big little trucksFound a friend that makes the power wagon look tiny
Exactly. Ideally one inch, but I'm not sure there's enough depth in those pockets.Looking to add a spacer with built in studs?
Is that thing on 40s?Found a friend that makes the power wagon look tiny
I've seen plenty of people cut the studs shorter to clear the wheel hub pockets. I would just make sure to cut them with the lug nut on it. Then after the cut you can back the nut out to clean up the threads.Exactly. Ideally one inch, but I'm not sure there's enough depth in those pockets.
Yeah I believe it was on 40s with Dana axles.Is that thing on 40s?
I’d imagine the stock JT Rubicon is more capable offroad out of the box than a Power Wagon. And that JT should be WAY more capable than my truck.Lots of money to build up that platform to perform like a PW
How large are you thinking on a spacer, and where from?I've seen plenty of people cut the studs shorter to clear the wheel hub pockets. I would just make sure to cut them with the lug nut on it. Then after the cut you can back the nut out to clean up the threads.
I'm looking at adding a hub centric spacer to the front to clear 37s. If I don't go with a whole new wheel.
Oh yeah I'm not new to any of this. I've had great results with Motorsport Tech/BORA wheel spacers and adapters in the past. They will make them any size you want, hubcentric to the vehicle, hubcentric to whatever wheel you're using, with or without studs. They do great work and are pretty fast too.I believe you're looking at a 15mm spacer to get the AEV inside clearance on stock PW wheels. I forget the exact specs, but they are on the forum somewhere. At 15mm you won't be able to get spacers with built in studs so you're going to want to use extended length studs. If you want the built in studs you're probably looking 1" (25mm) spacers at a minimum for that.
I wish more auto manufactures used lug bolts instead of lug nuts to mount wheels. I know BMW does and it makes it so much easier to run spacers haha.
It's easy to find reputable manufactures of spacers for car sizes, but I'm too new to the truck world to recommend a brand.
I used these guys in the past and they do truck bolt patterns and custom specs.
US Wheel Adapters, Wheel Spacers, & Hub Centric Rings
US Wheel Adapters | Best in US @cccustomsbuilds@cccustomsbuilds Guide To Adapters & RingsBolt Pattern & Hub Guide (.pdf) Wheel Adapters(Changewww.uswheeladapters.com
Ultimately, I will probably do a whole new wheel setup.
Subjective! LolI’d imagine the stock JT Rubicon is more capable offroad out of the box than a Power Wagon. And that JT should be WAY more capable than my truck.
But, I think Power Wagon is more comfortable and still able to work hard.
BOTH Power Wagon and JT have their pros and cons.
