I suspect you are talking about the module under the jump seat or console on the cab floor. that is a good point and I have been very careful around it. While in between the swap, I covered it with a plastic container to protect it from anything happening to it.That is the air bag module so be gentle with it
I *think* it will fit, but I can't honestly for sure it will. The ones on ebay seem to think they fit. You might want to check with the dealer to see if it is cross referenced. I was lucky enough to find someone with the same 2500 Laramie.Anyone know if the center console from a 1500 will swap into a 2500? I just picked up a 2500 with jump seat and want to swap to a center console but only finding 1500 consoles for sale.
After some digging looks like the 1500 consoles may not be exactly the same as the 2500. Some parts share the same part numbers (arm rest, cup holder, rear vents) but the main console base is a different part number. Seems really odd because they look identical. Im still tempted to just buy a used 1500 console and try it out but most likely will just buy everything new from the dealer.I *think* it will fit, but I can't honestly for sure it will. The ones on ebay seem to think they fit. You might want to check with the dealer to see if it is cross referenced. I was lucky enough to find someone with the same 2500 Laramie.
For me, I had to buy the wiring harness because the guy I swapped with used the one from the console for the jump seat. If you get a wiring harness with the console you may be able to use that. Yes, I purchased and used the usb extension cables for the front two usb ports.After some digging looks like the 1500 consoles may not be exactly the same as the 2500. Some parts share the same part numbers (arm rest, cup holder, rear vents) but the main console base is a different part number. Seems really odd because they look identical. Im still tempted to just buy a used 1500 console and try it out but most likely will just buy everything new from the dealer.
For the wiring, you have to purchase a new harness for the center console and also use USB extension cables, correct? Did you ever find out why your rear USB ports were not working?
Got it. Is there any reason you couldnt use the harness from the jump seat in the new center console setup?For me, I had to buy the wiring harness because the guy I swapped with used the one from the console for the jump seat. If you get a wiring harness with the console you may be able to use that. Yes, I purchased and used the usb extension cables for the front two usb ports.
I have not dug into the rear two usb ports working yet. I am convinced it is an issue with the wiring harness missing the power to the usb ports. They are powered usb ports like the front. I believe if I run a pig tail from the unused power wiring that was for the front tray, to the H-connector harness, it will work. Does that make sense?
There a few problems when trying to use the jump seat harness on the console.Got it. Is there any reason you couldnt use the harness from the jump seat in the new center console setup?
Assuming I have to buy a new console from the dealer and I wont be giving my jump seat to anyone would it work if I took the harness out of the jump seat and put it in the console? Seems like all the ports are roughly in the same areas. I havent started taking things apart so Im just guessing here.
Thanks for all the info!There a few problems when trying to use the jump seat harness on the console.
1. The wiring had to be cut to remove the wiring from the USB port inside the jump seat storage bin.
2. The original front dash wires were not long enough to attach to the console USB ports.
3. The original front dash wires (USB power) were also not long enough.
On the console the storage bin USB had a connector that had a matching connector with the console wiring. You would have to tear the jump seat apart to get at it. Why they did not do this with the jump seat is a mystery. Point 1 for using the console wiring harness.
The console wiring harness fit to the front USB ports, but did not work. The USB power did work. So, I used the USB extension cable from the original dash wiring to the USB ports in the console. Point 2 for the console wiring harness is the working USB power.
If I wanted to extend the wires and place a connector rear storage bin USB, that would would have worked. The console wiring harness seamed to be the best route.
Given that the jump seat only had the rear USB power fed from the harness and the front was separately fed from the front, I believe the body H connector only had one USB power configured. That mated up with the front console USB power and not the rear. I believe I will have to either make a separate wiring harness to reach the front USB power to rear USB power ports or a connector from the front USB power to the console wiring H connector and tap into that.
You most likely could get the original wiring to work if you add an extension cable (i.e. make) for the front USB power, use the USB extension cables, and rework the rear USB in the storage bin with a connector that matched the connector on the console. Just a guess.
I hope this helps.
Cool, please let me know how the wiring works out for you. I might be interested, as I don't have the contacts.Thanks for all the info!
Im going to be ordering everything from the dealer and piecing it together this week. We'll see how the wiring goes. I manage an auto body shop so install should be a breeze I also have a vendor that builds wiring harnesses so may have them help me out.
The diagram and parts list my dealer sent me lists two lamps inside the console. Does yours have any lights inside? Wondering if this is maybe an extra option on the Limited models.
I have a jump seat setup for sale. I just finished swapping to a console.Does anyone have the opposite?! Console to jumper seat???? I wanted a jumper seat and settled with the console.
Is it for a Laramie?I have a jump seat setup for sale. I just finished swapping to a console.
Have jump seat. Would like console. Where are you located?Does anyone have the opposite?! Console to jumper seat???? I wanted a jumper seat and settled with the console.
